The relay was one of the first parts replaced. After completely resoldering the connector board on the back it hasn’t reoccurred. There was nothing visually obvious on this board under a magnifying viewer and yes, I reattached the grounding wire. When this happens there is a loud snap, crackle and pop… plus the the woofers extend outward - both speakers. Prior it sounds fantastic and looks that way on the scope with all voltages good.
The entire power regulator board has been replaced. The mode switches, power filters, diodes, all the known bad transistors plus entirely recapped with everything 10uf and under in the signal path films. It’s quite abrupt and like destroy your speakers bad. Everything physical cleaned and continuity tested.
It’s played 3 or 4 hours now clean. The prior time it was after playing all day. I assume this is why it was sold. Clean as new and not a physical indicator of heat or damage. Driving the amp with a separate preamp it’s clean and solid.
I have repaired and restored almost every notable unit and brand and 100’s of them so assume my technique and skill set is good. This one is a head scratcher
