Perhaps..Is there any Multimeter tests I can do to help track the problem?
Yes. The problem change. Right channel gets lower than right.Hook an interconnect cable from Left pre-out to Right main - in as well as Right pre-out to left main-in -- Then flip the coupler swicth to the decouple position ( OFF )... Does the problem change channels ?
Tuner and CD through Aux.What are you using for and audio source ? Have you tried the AUX or TAPE inputs ?
Right. What shoud I check there? Is the pre-amp the equalizer amp?Left channel pre - amp
If this is still the case then both mono and reverse switches are probably dirty.When in reverse or Mono sound in left channel equals the right channel.
I have disassembled the switches and let them crystal clear. No way is dirty switches. Any other ideas?If this is still the case then both mono and reverse switches are probably dirty.
Using a multimeter, select AUX1 input, insert one probe into female/inner of left AUX1 RCA connector at rear. Connect other
probe to left channel (white wire) on mode circuit board, measure resistance, amp powered off. Repeat for right AUX1 RCA
female and right channel (red wire) on mode board. You might get lucky...
Equalizer amp? Is there any Multimeter tests I can do to help track the problem?
I've done the Ohm tests.Measure the resistance as above, maybe takes 5 minutes
yesIs the pre-amp the equalizer amp?
Do you think I shoud start removing transistor and resistances to check their values in equalizer amp?
Using the Tuner by-passes the EQ amp -- Have you did anything with the TAPE MONITOR. switches ?Tuner and CD through Aux.
No.. See previous post..Do you think I shoud start removing transistor and resistances to check their values in equalizer amp?
1K Ohm and 0,991K Ohm is within the specs?Measure the resistance as above, maybe takes 5 minutes
No. Not to TAPE. (Not disassemble them, just sprayed.)Using the Tuner by-passes the EQ amp -- Have you did anything with the TAPE MONITOR. switches ?
Plz confirm that the red/pink and white wires you measured were in a white plastic wrap. Looks like you measured1K Ohm and 0,991K Ohm is within the specs?
