Yamaha newbie A-700 resto thread
Look at the Yamaha A-1 . I have a bunch, I kinda collect them. Not dual mono transformers but hey have 2 used in I believe parallel . Cant remember exactly but
they have a super great Phono Section and sound awesome. Very heavy as well.
A lite hard to work on with respect to disassembly .
The two beefy transformers are connected in parallel to cancel their respective leakage flux and the two big 18,000µF Nichicon caps are bypassed with two 2,2µF metallized mylar film caps.
A favorite of mine.
Nashou
Oh that looks sweet. Gonna read more about it. Would love to get a silver one...
I'm gonna start exploring Yamaha more now. Did they ever make an integrated with true dual mono transformers and power supplies?
This is my first Yamaha integrated so I don't know. I mainly use separates. M-80,M-85, MX-1, MX-1000 has dual xfmr's.
Get to work on that 1020
Gotta big digi-key order enroute. Finally ordered stuff. That job should go quick after parts arrive...unless it blows up. :biggrin:
...I kind of like taking everything off of the board if it's not going to be crazy to put back together. You can clean it so well when it's naked. On the power amp boards on my Kenwood, I took after someone else here that I saw and printed the board diagrams out and stuck the parts through the paper to keep track of where they go. It was really helpful and the boards got so much cleaner after:
I very seldom remove more than one part at a time because I can get confused about which one went where, especially if I have taken a break from the project.
I also make a complete photo survey of the entire unit before starting. That helps a lot when I get confused about what went where.
Cheers,
James
What do you guys clean the component side of the ckt boards with? I've been using 90% isopropyl alcohol with a paint brush. I'm still shy about board disassembly unless it's a real mess. As a hobbyist mechanic, I can find wiggle room in any tight spot. I figure the unit is gonna get dusty again anyway. :blah:
I should probably use alcohol but hate to waste good sipping whiskey so I use acetone.
James
I use 99% IPA, a spray bottle, and a paintbrush. I shared where I got my method on a post in my KA-3500 thread:
Yeah, Prime HIFI is pretty good.
India Pale Ale?
:beerchug:,
James
No hum at all, actually. I was surprised by that because before I fixed it, there was definitely a slight hum. Now there's nothing. Very odd
Good to hear. Probably from all the good board cleaning & solder touch ups. I 've been toying with a solder the fuse theory. Thanks for the feedback bud.
