Yamaha newbie A-700 resto thread
While I am blabbering about stuff, I do not know how much tolerance we can accept from nominal in a zener before it starts to adversely affect a circuit. That would be a question that someone like Avionic can answer better than I will ever be able to.
I had a really tough time finding the exact ones that I needed for my Denon project, so I ordered a half dozen different ones for each of my different voltages.
This is where the Zen 50 is a really nice tool. It displays the zener voltage, forward voltage drop and resistance. So I was able to use it to quickly get an idea of which of the variants that I bought was in the range that I wanted, and sort through them to find matched pairs for the positions that I needed.
Now, I don't know if a few tenths of a volt difference will make a problem when you have 2 zeners working together for a specific voltage on + and - rails, it might be time better spent drinking beer, but I also figure that you also can not go wrong by matching them.
Cheers,
James
500mW.
I just wanted our friend Soundscape to get enough to read. :biggrin:
I'm not so sure that you can buy HZ or HZ-L any longer. Mouser doesn't have any.
Cheers,
James
Thanks, I'm getting data sheet headaches dudes. Check out this bullshit! I ordered these and installed them in my A. Ahem, A-1020. The f'ing manufacturer data sheets show the nominal voltage as 5.75 while Digikey shows it as 5.95. Which would be perfect cuz the old pricks are 5.8 - 6.1 , 5.95 nominal jones.
Now I don't know what to believe and my A is full of them now.
I couldn't find them. The replacement I have coming today is NZX6V2, with the "B" rating the same 5.8 to 6.1 listed for HZ-6 "C1" in its datasheet.
Same issue with that damn B&C rating. Obsessing over it too much I spose. The ones you ordered are the same ones crammed in my A.
If you got that part # from a local Sensei I'll just crumple these datasheets & crack a brew. F it
This is exactly why I ordered a spread of different parts for the values that I was looking for. The stated info at Mouser etc did not inspire me, so I hedged my bets. At a few € for 100 of each it was cheaper to buy too many parts than make a second order.
The Zen 50 was not cheap, something like €75, but it is the only test device that I could find that will quickly test the zener voltage.
James
You can use a bench top power supply and a 1k resistor to test a zener, or a 9v battery if the zener is under 9v.
The resistor limits the current I believe, simply put it in series with the zener and connect to the power source, set the psu to a voltage above the zener voltage and use your DMM to measure the voltage drop across the diode.
The Zen 50 is a f#€k of a lot easier.
Cheers,
James
Cheers,
James
The TC-1 can do zener voltage, but who knows how accurate it actually is.
Cheers,
James
Thanks Mr. Bratwurst. I just now built your ckt idea with the 9 volt battery jones. Tested 2 zeners in link below with a dead nuts accurate Fluke.
1 was 5.96
2nd was 5.97
Good enough for me
The manufacturers data sheets are dicked up.
As promised, right channel replacements...
I checked the following by pulling and using the TC1 tester, they all tested OK with that. Not sure how much that's actually worth.
TR104 TR106 TR108 TR110 TR112 TR114 TR116 TR118 TR120 TR122 TR124 TR132 TR134 TR144 TR146 TR147 TR148
And the replaced transistors...
Location (S/M)Original P/NReplaced With?
TR1262SD400BD13516S
TR1282SC2705KSC2383O
TR1302SA1145KSA1013Y
TR1362SC3298MJE15032G
TR1382SA1306AMJE15033G
TR1402SC33702SC3857
TR1422SA13332SA1493
Diodes...
D108HZ6C-1LNOT YET
D1101S1555NOT YET
D1161S15551N4148
Someone yell at me if you want voltages and I will oblige.
See if it works...
Well, I plugged it into the wall and sparks started flying...
Just kidding!!! Relay kicked in after about 5 seconds no problem!!! Let it warm up and bias is locked in!
Both channels are in, I didn't take a pic of the 2nd one!
Hooked up speakers and guess what else - BOTH CHANNELS WORK PERFECTLY!! No more mysterious missing channel!!!
All of the inputs are dead quiet, tone controls and loudness work beautifully, balance/volume are smooth and silent, muting is working great... I'm afraid to use class A mode right now. Direct works too but why would I want to bypass all of those WIMAs... lol.
It seems too good to be true, I finally get to use this emoticon!!! :banana:
I got zip ties to put on wire bundles, screws to put back in, and just get everything back together but THANK YOU everyone who helped me with this. More pics to come!!! :jump:
