AFAIk the zeners act as voltage regulators. Above their stated "zener voltage" they allow reverse current, effectively diverting all voltage above that level on that rail to ground.
It is important to find a data sheet and find the exact sub-class of the zener. The zener voltage will be shown as a range for each sub-class. I then calculate the nominal value from that for ordering purposes.
I found that it is getting harder and harder to find a lot of sub-classes of through hole zeners, the last time that I ordered some from Mouser they were back ordered for months.
Just in case it is what is needed, I am attaching the HZ series datasheet here. HZ zeners are pretty common in Yamaha amps I think.
Cheers,
James
Cheers,
James
