Yamaha RX-730
With amp powered off/unplugged check resistors R230 & R232, probably one is open.
Power on the amp, connect black probe to pin 9, select 20Vac scale on MM, measure Vac one side of R232, repeat for otherside. Measure Vac at pin 10.
Unplugged: R230 - 308 ohm, continuity - OL; R232 - 5.1 ohm, continuity - beep; R 231 - 14 Mohm, continuity - OL;
Power ON: pin 9 (black) to pin 10 Vac = 0; each side of the R232 Vac = 2 mV ac;
What about voltage AC on either side of R230?
Nashou
  • Like
Reactions: mbz
Zero for both.
Can you give a larger area of this part of the schematic? More to the right and top, but keep the tranny in the picture?
There might be a circuit that keeps that tranny off until another circuit is engaged. I don't have the schematics to check.
rx-730-10-jpg.3701343
  • Like
Reactions: mbz
