So onto my conclusion post I guess, unless the unit nukes itself...
Things to note:
When rebuilding these amps always verify that you have +-.5-.7v on your predriver collector/cans, this is the bias voltage and should adjust with the pot, if not it is not safe to install outputs.
The bias voltage is directly affected by your DC offset in early revisions of this amp. Not entirely sure why but I believe it's because the DC adjustment interacts with your +-.7v. regardless, if you see a huge difference between the +.7 and -.7 then chances are your DC offset is adjusted incorrectly, or your diff pair is too low gain, or potential issues elsewhere.
ALWAYS test the drivers in the Amplifier, the "good channel" in my amp had one with a normal HFE of 60 and the other with a damaged HFE of 13, was just waiting to blow. That being said, predriver matching seems to be much more important than driver matching as this is the 2nd unit I've done that's been stable with one driver at 90 or so HFE and one driver at 170 or so HFE, I think Marantz may have some tolerance on the gain ranges provided.
If you have no bias movement on a 100w bulb with both channels (I ran into this) try a 150 or 200w bulb, the Vdrop from the 100w bulb can be high enough to prevent the amp from biasing.
MJE180G worked just fine for my bias Transistor once I installed the higher HFE diff pair, but ymmv since Marantz made so many mid production changes.
Check your resistors, especially solid carbon ones, they like to drift.
Anyway, as for my parts list:
2N4250 - PN4250
SPS1951 - BC547A
SPS 1952 - BC560C
2N4125 - 2N3906
2N4123 - 2N3904
MPSA20 - Central Semi MPSA20 (Still made)
Differential pair:
SPS1928 - 2N5089 matched with HFEs over 800. Gain is critical here due to how the DC circuit affects bias. BC550C would probably work too, but the pinouts are different.
Predrivers:
(gain match critical between NPN and PNP)
SJ2582 - 2N5415
SJ2583 - 2N3440
Drivers: (MJE parts should work, however you may have to order a few of each P/N of the PNP due to gain)
Using the below parts I was able to reasonably match the requirements set by Marantz. If you use MJE15031 you may wind up with 300+ HFE which wouldn't work, unfortunately it is luck of the draw as they don't bin these parts by gain.
SJ2585 - MJE15033
SJ2586 - MJE15032
Outputs:
SJ2520/2519 - used MJ21195/96 here due to availability, luckily these rarely differ by much in HFE.
MPSA93 or SPS2324 - used modern production MPSA93
MPSA43 or SPS2325 - used NTE287 due to availability
Bias diode replaced with NOS original part. Both did test okay however.
Relay board:
Rectifier Diodes:
MR752 - HER605G
1N4003 - UF4004
Relay:
OMRON MY2-DC24 - modified in by swapping pins 13 and 9 as well as 12 and 14. Check that your DC supply is within +-10% of 24V, mine was not (was closer to 30V) so a dropper resistor was added to extend coil life.
Transistors:
SS47 - MJ182G
SPS438 - BC546B
All that's left now is to modify in some better RCA connectors (if I feel like it) and this one should be good to go!
One thing I would possibly consider is modifying in larger predriver heatsinks, with the stock heatsink they run very hot.
