So, I'm using the safety trick I learned on my 250M, you can measure your voltage that is used for bias on the collectors of Q507 and Q508, you should have something reasonably close to +.6v and -.6v.
It allows for testing without outputs installed
goldswimmerb,
I am getting really to test the Maranatz 250 amp boards I just repaired. See images below. I was hoping to test before installing the output transistors as you suggested above. Can you help me out with some step-by-step test sequences that a sixth grader can understand?
When I received the amplifier back from a fellow AK member who worked on it, and it failed after a few hours of play (protection replay would not click-on), he told me to remove the output transistors in one channel at a time. I took out one set, and tried to power it on. it still failed. I then took the other set out of the other channel and tried again — and it powered-up and protection relay kick-in. So I know from experience that you can power the amp without the output transistors in. However, then I foolishly didn’t have a DBT. I didn’t do any damage. But now I do.
When I power this amplifier back on, I will do so with a new isolation transformer, a new Variac, and a DBT with either 100 or 150w bulb. I also have a new Siglent SDS120X-E Oscilloscope that I have never used before.
The main filter caps are fully discharged and all wires removed.
I was planning on connecting one channel amp board at a time but I’m not sure if that that’s right. I made identical changes to both amp boards. Powering both on and testing each channel for results against the other seems to make sense to me. Besides, both amp boards are only mounted to heat sinks and not to the chassis so they are easy to access when I power it up. At least I think it can be powered-up in this manner.
Everything has been updated on these boards. Everything is matched. I have researched every component and substitution. I feel pretty comfortable with the work that has been done. But now its time to power-it-up and see.
I turned both BIAS points all the way counterclockwise as directed by the Marantz Service Manual. So they will need to be set.
I do not believe I can set BIAS until the output transistors are back in, however. Is that correct?
I would like to ask you EXACTLY where I should be placing my DMM probes in initial testing. I don’t want to make any mistakes. I worked too hard to get to this point. For instance, you mentioned the voltage in Q507 and Q508. I have installed new 2N5416 PNP and 2N3440 NPN in place of the S39613 and SJ2582. I assume you apply test probes to the back side of the board at the solder joints. See images. The Collector is the pin farthest from the tab. See image. So do you place one probe on Collector and one on Base or Emitter? And its different for NPN vs PNP, correct?
What about testing other voltages? Is there one or two other places to test to check? Do you ever test with the black probe to chassis ground? Or always between two places on the board?
And what about BIAS? Marantz gives different methods in different manually that seem strange. See the attached update method. Do you apply the red probe on one location and the black probe on the other? I am totally confused because I get so much conflicting information on how to check and set BIAS.
I thought I’d ask and pick your brain. But I need to be shown how. I don’t have enough experience. I should have been born in the “Show Me” State of Missouri!
Thank you for any reply in advance. The images is of the amp boards are as they are now after changes. One is labeled and one back is labeled with pin locations for Q507 & Q508.
Rob
