Interesting. If you are replacing SPS1928s they definitely need to have high gain, in the 700 range. The 240 uses 2N5961 from factory which has lower hFE but it uses a pair of transistors in the bias section so these things could be related.And my only conclusion, at this point, is that the gain of the differential pair is absolutely critical in getting the bias voltage correct on the positive half of the Amplifier.
2N4250s also have high gain, in the 400-500 area, I managed to get some and used them in the 1200 tone board. I find it interesting that the 250 reaches 125W because it has +-58V rails whereas the 1200 is rated at 100W and it has +-52V rais. The amp boards are basically the same.
