Just to be sure readers understand this, Eminence Delta-10A is a "Midrange Driver:"
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-412
You're building "Mid/high" boxes with those, or similar, and will need a sub, or several, to provide bass.
In pro SR, (Sound Reinforcement,) bass is 40 Hz, generally; the bottom octave is missing. Providing extended bass at the requisite SPLs in large spaces is possible, but difficult, and also difficult to manage. A pro sub conforms to different performance criteria than those more suited to home use, in smaller rooms.
Does "Mid/high" work at home? Sure. It's "Sub/satellite" separates we're talking here, in some respects a better approach than integrated 3-ways, in fact, and satellites don't have to be the dinky "theater in a box" speakers with which we are all familiar.
EconoWave is especially well suited to mating with high-efficiency midbass drivers such as are being discussed here. Look again to pro SR. Any tweeters there, in the conventional sense? Nope, it's compression drivers on horns/waveguides, virtually universally. E'Wave's sensitivity, fully HF compensated, is ~100 dB/1W. As Wayne pointed out earlier, there are few woofers or midbass drivers that'll outpace it; a mid/high system built with it can run on milliwatts for most home use.
So, we have two basic design approaches using E'Wave:
1) Combined with an extended-bass woofer to build full-range 2-way:
2) With a higher-efficiency midbass driver for use with subwoofer low-frequency augmentation:
OR, any intermediate combination in between.... :thmbsp:
http://audiokarma.org/forums/showthread.php?p=2260584#post2260584
