zilcher may be on to something.
As soon as I can access my L55s here, which have LE14H-3 in them, I'll illustrate your design. The integrated "tower" version of it would indeed be patterned after S4600, which uses LE14H-4 to provide bass more in line with Asian listening preferences. It is not available to the U.S. market. More on that below.
Here are the cabs I used to build my "2.5" towers using LE14H-1 pairs and E'Wave; a couple pair of the empty cabs were available in the JBL Pro Tent Sale, and I snatched them up:
http://www.jblproservice.com/pdf/Array Series/4894A-90.pdf
With that as background, here's the skinny on the drivers, as best I know it:
1) LE14H-1 and LE14H-3 are sonically interchangeable, H-3 being the more recent design. Greg Timbers suggests they are a drop-in replacement for H-1 in L250Ti; good enough for me, since he's the designer.
2) LE14H-4 has less Aquaplas on the cone, and thus, does not generate the extended bass of the "standard" LE14s, suggesting also that it also has more articulate midrange, and might appropriately be designed into a 2.5 alignment.
3) I have H-1s in my 2.5 towers because the two chambers are small and the tuning is 10 Hz too high; that's how I get extended bass out of them. Converted to a single volume, they're up somewhere between 2.4 and 2.8 cuft., and a single LE14A/-1/3 will do the job tuned to 30 Hz. Done.
4) I'd put LE14H-4 pairs in them but: a) the volume may still be a bit too small, b) that's a substaintial investment in new woofers for an "experimental" design, and 3) they are virtually unobtainable; it's tough enough sourcing JBL high-end drivers used in products actually sold in the U.S.
5) While LE14As do not have the improved capabilities of these more modern variants, they are plentiful and relatively inexpensive, and thus an appropriate driver for E'Wave builders. As you observe, they'll work nicely in modest-sized cabinets, and make delicious extended bass.
Footnote: JBL and others also made/make subs using LE14H-1 and H-3. LE14A will work for that, too, with somewhat higher distortion and lower power handling, less of an issue with multiples. See Citation 7.4.... :yes:
Edit: Here 'tis:
http://audiokarma.org/forums/showthread.php?p=2339479&posted=1#post2339479
