It's virtually a given that the lowpass should be tweaked for optimum performance with E'Wave.I was using the 8-ohm woofer XO, for my "8-Ohm" rated JBL 123A-1s. Well, they're specified with an Re of 4.4 or so. Maybe I needed to use the 4-ohm type.
Re is the DC resistance, not the impedance, so your assumptions may not be valid. I just measured a pair, in closed boxes, and the actual impedances at our nominal crossover frequency of 1.6 kHz are 9.6243 and 9.4090 Ohms. A "correct" Zobel has the potential of lowering that to ~5.0 Ohms, looks like:
Did you see my earlier post on this subject:
http://audiokarma.org/forums/showthread.php?p=2266540&highlight=123A-1#post2266540
I have not yet verified those values, but it appears that we have arrived at nearly the same place.
Note also that 123A-1 is a positive polarity woofer, a JBL rarity, so the Selenium polarity should be reversed per the standard E'Wave schematic.... :yes:
