Heh, heh.
Geddes would likely be quite proud, indeed.
We can apparently restore full constant directivity by using an appropriate screen grille, which will require some experimentation. Think "Transparent sunshade...." :yes:
Here's the BMS 4555 results:
The waveguide shape then evolves tangentially in an increased curvature in the flange region to form an exit opening that blends tangentially to vertical surfaces of the frontal plane which extend to the cabinet edges.
Thanks.
