I wish you DOT guys would just refoam. Your LE14s are out of control....
I knew you wouldn't Approve!!
Did it more for an experiment and to say, I HAD DONE IT.
(Figured I got nothing to loose, worse case I refoam them)
I have another set coming, I am hoping I can get 1 pair with decent Lansaloy an
compare those to a set I'll refoam, take measurements and listening impressions.
Read a few threads over on LHF where a ("tech" I believe) described the process
of if you are going to do it, then do it right. :scratch2:
So I applied it to the back, they were not moving at all previously but completely
intact, first coat after a bit got it moving, ran woofer tester with FS of 90 or so.
Worked in a bit more got it to an FS of 70, let it sit overnight, got an FS of 47, I
applied a tad more an worked the surround, got it to an FS of 40.
Left it at that cleanded it up, let sit another day, FS stayed at about 42, I then
installed it back in the cab, threw a North Creek tweet in there so I could play it
for a while, maybe loosen up a bit more then I'll recheck the FS to see.
Yes pretty much an experiment, but if I can get 1 pair to around an FS of 30, an
the surrounds look good I'll leave 1 pair like that until I "have" to change them.
