Duffinator
Spin The Black Circle
I'm pretty sure it does. Zilch?So if the L620 is a 6-ohm speaker, does this imply that the woofer is, as well?
Not necessarily; gotta measure to be sure. They may have called the minimum impedance "nominal."I'm pretty sure it does. Zilch?
I'll measure some ADS woofers and post the impedance plots if others feel it worthy?
Here are WT3 tests of Yamaha Woofers from NS-500, NS-500M and NS-690 II including measured Thiel - Small specs:
NS-500 woofer: JA-2508 vas 2.945 spl=91 db/1W/1M
NS-500M woofer: JA-3109 vas 3.171 spl=92 db/1W/1M
NS-690 II woofer: JA-3060 vas 2.718 spl=88 db/1W/1M
Thanks Kegger.
Your basic 2-way E'Wave is not going to work with side-firing woofers, so it'll have to be 3-way, substituting the 6" square waveguide for those tweeters. Not worth it, I wouldn't think.What would you do if you were going to do an Ewave project with these?
You might just stick the $7.99 P-Audio clearance specials in them instead, and call them "Done."
I'd venture to say that's Econo-wave exclusive info... you saw it here first!Here are WT3 tests of Yamaha Woofers from NS-500, NS-500M and NS-690 II including measured Thiel - Small specs:
Thanks Kegger.
Looks like *I* slathered the glue in there....Anything more serious deserves a much better cabinet.
During the summer between high school and college I worked at a white van speaker manufacture assembly plant. Glue is cheap and we used excessive amounts of it. Most of the employees fought over who would get to work at the glue (sniffing) station.Man, think they used enough glue?
During the summer between high school and college I worked at a white van speaker manufacture assembly plant. Glue is cheap and we used excessive amounts of it. Most of the employees fought over who would get to work at the glue (sniffing) station.![]()
Perhaps the name "DUCKINATOR" might be more appropriate around here after admitting that..During the summer between high school and college I worked at a white van speaker manufacture assembly plant. Glue is cheap and we used excessive amounts of it. Most of the employees fought over who would get to work at the glue (sniffing) station.![]()
