They're all over the place here, but:Zilch, have you heard a difference in a CC network? I am guessing you have tried it on an occasion or two...![]()
That's what I'd be looking for, some measurable means of showing the effect of the CC in place. I get the idea, and I suspect that not everyone is crazy here who thinks it sounds better, but would love to see the effect backed with objective data.
The PT waveguides are constant directivity, and edge diffraction appears to be less of an issue. Many E'Wavers are running them freestanding, with no baffle.
Indeed, many E'Wavers would likely be quite interested in how that combination might perform.... :yes:So if I get B&C DE250s and adaptors to use with the $9.90 econo-JBL waveguide, can I still be an honorary EWG club member?
Thus, the tie point between the two caps sits at 9V rather than 0V, and is modulated by the AC signal passing through. You have to be applying an 18V P-P AC signal to drive it down to the capacitor's zero voltage crossing, which is mighty damn loud. It's DC bias and can't flow out of the caps, the only drain being leakage, which is constantly refreshed by the 1.5 or 2.2 meg resistor.
The current available from the 2.2 meg source affords little competition to the low impedance AC signal. Even staying centered at the 9V operating point relies upon that signal being symmetrical, statistically:There may be some modulation by the AC but it's still a DC source. You have the Time constant of the 2.2meg times the capacitance value to deal with as well. Just like you do in a conventional power supply. You are never going to drive the caps through 0 volts.
The current available from the 2.2 meg source affords little competition to the AC signal. Even staying centered at the 9V operating point relies upon that signal being symmetrical, statistically:
Hello Zilch
There may be some modulation by the AC but it's still a DC source. You have the Time constant of the 2.2meg times the capacitance value to deal with as well. Just like you do in a conventional power supply. You are never going to drive the caps through 0 volts. You have a very clever and simple AC and DC circuit there. For AC it's a short through the caps and an open for the battery. For DC, once the caps are charged you have very little current draw on the battery and the capacitor discharge time is set by the resistor and capacitor value time constant. The discharge is not linear just like the initial charge time is not.
Rob
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capchg.html
If one side of the cap is charged at +9VDC, then the dielectric of the cap will have exactly zero volts across it when the peak of the incoming AC signal equals +9V. This occurs with a steady state sine wave when the RMS value equals 9 / (sqrt)2 = ~ 9 X .707 = 6.36VAC.
I'm just suggesting that the time constant has little to do with it.
You need a sustained voltage to bring them to zero that exceeds that time duration. You need 5T for a 99% charge or discharge. My point is it won't happen with music.
Rob![]()
Well, I'm gonna have to set it up again and retest with dummy loads and sinewave input. I believe I understand where Rob and I disagree, and that relates to whether the discharge path is the 2.2 meg or the source and/or load impedance. In the meantime, there's this, which may be read as saying Greg Timbers agrees with Rob:So then is a simple test like feeding a sine wave in HF region and looking at hi x-o output through a scope not valid or useful?![]()
Welcome to the E'Wave adventure!Just sticking a little toe in to test the water on this whole e'wave thing.
Nope, we have "official" E'Waveguides as small as 6" square now, and there's nothing inherent in the principles practiced here which would preclude E'Waving Minimus 7, even.I have a few questions:
Is there a minimum size that will work for the project?
Understand that E'Wave is essentially a high-frequency section, a tweeter replacement, if you will, thus far primarily used in two-way systems. As tweeters go, it's a fairly expensive substitute at $168 nominal per pair, but it is much more than just that, rather, a high-performance engineered system incorporating features transcending what is possible with conventional designs which can transform existing systems. Several of us have been astonished by what occurs when E'Wave is mated with Advent woofers and inexpensive Daytons, for example; it'll work with any woofer that can play competently up into its nominal 1.6 kHz crossover region. That's not to say that the sonic character is not substantially dependent upon the quality of the low frequency portion, but many builders have been pleasantly surprised by the achievable results with what might otherwise be considered "pedestrian" woofers.Can you achieve improvements with drivers over a broad range of quality - in other words, is it not worth the effort without something like the JBL drivers I have seen discussed in several posts?
Absolutely.I have a couple of very substantial cabinets that housed Fairfax 300x speakers. I replaced the tweeters when I first got them, and when I stupidly blew a woofer testing a bad cassette deck, I replaced the woofers with 10" Dynacos. The outer dimensions of the cabinets are 22" x 14" x 11." Would cabinets that small work with the e'wave concept?
Very likely. There have been discussions in this thread regarding designing with A-25 woofers, and one member has tried E'Wave with A-25 itself here, as well, to good outcome.Would the Dynaco drivers suffice to provide the bottom half of the project?
The vertical beamwidth of the standard waveguide is 50° with constant directivity, effectively wider than many tweeters. With the 6" square waveguide, this expands to 90°, which few other designs can even approach. If it's not possible or desireable to elevate the waveguide axis to listening height, aiming it there will easily suffice, yes.Finally, because of the relatively low profile of the cabinets, would placement on a short, slightly angled stand interfere with the direction of the sound waves?
You are very welcome, of course, and I hope you find this reply responsive to your concerns.... :thmbsp:Thanks for any information.
