These peaks?
Am I right in thinking that the optimum value of the resistor in the Zobel would vary with woofer impedance? I am using a very close cousin to your crossover, but with values adjusted for a 16 ohm woofer (Altec 515E). Then someone loaned me a pair of JBL LE15B with a measured Re of about 3.4 ohms. Last night I altered the value of L2 and C2, but I think the zobel resistor should be adjusted too. It didn't occur to me till I read your post, but I was getting some "shout" at the upper end of the LF, and figured I just needed to adjust the slope with C2. Now I'm wondering about that resistor, which is 16R in my case... I've got enough 10W 16R to parallel 3 or 4 for this application.
The woofer is in a giant backloaded horn, and I've got huge SPL with a little SE 845 power. I'm not worried about power levels.
BTW, I'm using a 2" constant directivity horn with JBL 2441. It's the non-econo version of the EWG two-way. But the zobel value WRT woofer impedance is a straight EWG question anyway, eh?
