Zilch referred to Wayne Parhams crossover document just about the time I was starting to design a crossover for the EconoWave. It really made sense to me, although it was a pretty long read, and left some things not covered. I used the principles and formulas described by Wayne, along with some things that I figured out, to design the EconoWave crossovers. Zilch has verified that the match to the desired response is spot on.
I gave Wayne the proper credit then, and do so again here. It would have been much more difficult if Waynes paper hadn't been available to me. So again, thank you Wayne.
Sorry, I didnt mean to offend and say they are horns...they just look like all the other horns I have seen so its hard for me to tell the difference.
I will have to research what separates a waveguide from a horn.
I did some searches on Phase issues and I didnt come up with the answer but myself and others from AVS are curious on how you guys handle the fact that the compression driver sits behind the acoustical center of the woofer?
No build thread for me yet but I did just purchase the PH612 and D220 from parts express...$107 shipped seems like a great start![]()
All you need to do is wade through this thread and all its ancillaries and you'll have your answer. do the 101 thing, and you will have learned more about speakers than you could imagine, regardless of how or how not experienced one is. Many of the same questions that were here in the begining are asked over and over as new folks come to this thread. The thread is gigantic, much is friendly fluff that can be passed over, but all the good stuff is in there.:yes:
Russellc
Jack,
I'm slow at this - I just read Wayne's crossover doc last week! I wasn't suggesting Wayne wasn't given credit where it was due, I was just wondering if his crossover doc came into play in all this, and it looks like it did. It looked familiar and got me thinking.... Between this huge thread, and all the info on the LHF and Wayne's Pi Speakers site, I'm learning an awful lot!
Get your crossover parts before they sell out of 1.5 coils again!
Russellc
I read the first 50 pages, twice now.....its hard to get all the specifics down. Ancillaries are hard to follow too at times....very, very tedious but I will find everything.
I agree everything has been asked and I hate asking them again but after a certain amount of time I just break down and askI will continue to do the research.
Thanks! I will find the BOM again in this thread so I can buy them.
btw, anyone posting about what woofers they are buying to match with the Econo-wave guide?
For cheap price, several are using the Dayton classic 12 and 15 inch drivers. One of the thread favorites is to find an old clapped out set of old JBLs that have the LE14A drivers, and refoam them. I have personally used JBL 2225H and 2235H with great results, as have several other members.
Basically, you just need a woofer that plays nice up to 1200-1500 hz or so.
Post your finds and someone can comment. Before you know it you'll be building away!
Russellc
Yes, I know this is a bit elaborate for most people... but if you're industrious, it makes for an EXTREMELY potent, fast, clean woofer system...
Regards,
Gordon.
Again, its all in there, including charts, graphs etc. Hint: you'll notice the phase of the HF driver is reversed.
Also, the accoustic "center" of the woofer isnt always where it would appear physically, measurments must be done, and were1
Russellc
Reading all of the development posts.
FWIW, before I decided to do Ewaves I did take the time to plow through all of the discussion of waveguides, drivers, crossover points, compensation, spacing, woofer characteristics and a dozen other topics. I did some research, did the math, compared to other speaker designs and basically did all of the due diligence you're supposed to do before ordering parts or cutting wood.
I came away convinced that the basic PH612/Selenium/Ewave crossover top end setup was correctly designed. All of the issues had been worked out and accounted for with generally accepted practices. There are no problems tha thave been ignored or papered over. I ended up using the 'classic' Ewave top end to convert a pair of Large Advents. That build thread is referenced on Page 1. It was dead easy and went together exactly as it should have. No surprises or disappointments.
As hobby project build descriptions go, this one is as complete as they come. If I had just ordered the parts as described and thrown it together the results would have been the same as after doing the research and verification. On the other hand I did learn a lot in the process but the result is the same. I encourage anyone who wants to learn a LOT about this technology to follow the development of the thread, but if you want to just build it as designed you're not going to lose any thing in terms of performance. It's as close to plug/play as a project gets.
And they will probably sound even better when you do.i'm gonna cut holes in the baffle and permanently install the ewave inside the boxes.
