Bauhausler
Rational Subjectivist
Those look like Advent 5002s? I think. The ADCs to my ears are very "Advent like". I have this project on my list of things to do. It's a very long list, but I'd like to try it.
Looks like this:
A note about the DE10 compression driver: The .250" connector tabs are located on very thin and flimsy plastic extensions of the diaphragm frame. They flex with just a light pressure. Enough pressure to slide the connector on will immediately break the tab off. Installing the male .250" connector on teh tab requires pushing on the back of the tab frame. Rather a significant drawback for a Pro driver.
Looks like this:
No, 6.25" including driver, measured from the front of the mounting surface....This project sounds really interesting. I am going to keep an eye out for a suitable cabinet.
Does the Selenium driver need space behind it to breath? From looking at the specs, the wave guide is 6.25" deep and the driver is 2" deep, so will any cabinet that's deeper than 8.25" work? Thanks.
I'm thinking of doing a JBL/THX sort of thing... putting the 10" close together, playing them in parallel, and letting them "narrow the dispersion" in the vertical dimension as you approach the crossover point. Could wind up with something that tracks in dispersion, pretty closely between the two woofers and the E-wave...
Regards,
Gordon.
Ok im starting another pair and will be using these cabinets http://www.audiokarma.org/forums/showthread.php?t=196466 Do you guys think I need to remove the vertical strips of wood in front of the grills or can I probably get by leaving them in. Im putting 2235H and B&C DE610s on 338650-001 waveguides in here, they are approx 6.25 CF each, other than bracing which is definitely needed with these relics can any one come up with any other suggestions I might be overlooking or just plain too dumb to think of myself. Thanks
Im just gonna make new front baffles and save the originals, fortunately they screw in so its no problem switching them out.
They'll be fine. If you look in my Quick and Dirty 4430 thread over on LHF, you'll see that both Jack and I built with them. Go to the "Contents" page first. The recesses are much less of a factor in the performance when using constant directivity waveguides -- they're well outside the pattern.Hey,
There is a pair of L200 cabinets available in the Denver market. Would these require a new baffle to eliminate the existing recessed baffle? Would the extensions on the side negatively effect the performance of the waveguide?
The Zilchster's favorite 90° x 50° waveguide, I don't believe those narrow strips will affect much, so leave them there, if you like....Ok im starting another pair and will be using these cabinets http://www.audiokarma.org/forums/showthread.php?t=196466 Do you guys think I need to remove the vertical strips of wood in front of the grills or can I probably get by leaving them in. Im putting 2235H and B&C DE610s on 338650-001 waveguides in here, they are approx 6.25 CF each, other than bracing which is definitely needed with these relics can any one come up with any other suggestions I might be overlooking or just plain too dumb to think of myself. Thanks
HPM100 woofer:
Re: 4.7 ohms
Fs: 28.94
Qts: .493
Qes: .536
Qms: 6.22
Le: .21 mH <--very good!
Mms: 106g
Vas: 5.24 cu ft.
