ROSSO
So as I sit with QSC wg's and DE250's figuratively in hand, if center-to-center is important, then smaller woofer would be better??? If you had LE10A, 127H-1, LE120-H1 and LE14A to choose from, which would you surmise might produce the best result? Front mount the wg and back mount the woofer and overlap the flanges?http://www.audiokarma.org/forums/showthread.php?p=2867674#post2867674
...The primary variables are the center-to-center distance between the drivers and the frequency at crossover...
... how low can DE250 competently play on the QSC waveguide? Will the nulls at a lower crossover frequency effectively compensate for the consequential losses in vertical pattern control?![]()
