WopOnTour
Hoarder Extraordinaire
Roger that Zilch, Thanks!You've got a bunch of options for porting there. I think I'd work with the 5" opening and reduce it from behind with plywood and whatever duct size I needed.
I'm not sure anybody knows the 414 T/S parameters, but they're likely quite different from DC300. I don't have any, but I'm on the lookout for a pair. :yes:
Although I was messing around in WinISD today using the parameters for a 414-8E which are included in the current driver database (physically identical to the 8ohm version other than the voice coil I believe, but I can't seem to find info to verify the T/S data in WinISD anywhere) But it's looking like that by slightly enlarging one of the 2-inchers I could potentially ditch the ABS duct pipe.
Thanks for that Gordon. Sounds like I'm just "in between clubs" LOLYep. Just start out with twice the inductor size for the woofer (3mh instead of 1.5mh) and half the cap size (6uf instead of 12uf). Use the normal values on the E-wave highpass section.
You might want to over-size the woofer inductor a bit beyond that... you can always un-wind a little off of it, or decrease the cap size a bit, if there's not enough midrange. Maybe start with a 3.5mH...Regards,
Gordon.
No problem, sounds easy enough (and about a saw-off when it comes to $$ I figure)
But I never ordered anything for the crossover yet as I have a lot of misc parts in my caddy
I'll find a 3.25-3.5mH then check response and "wind-off" to optimize.
Thanks again
Regards
WopOnTour
