Read again where Jack built with LE10H; he may have told us there.If I'm going to order today I should figure out what inductors I need and order those at the same time. Is there an existing crossover in this thread that's suitable for the 210 and the LE10A? I've printed out and saved so many crossovers from this thread I'm not sure what's what any more.
The HF filter for both D210Ti and D220Ti is the same, but depends upon woofer sensitivity....
So has anyone tried these with a tweeter plugged Large Advent system? Good bass and about a 1200hz crossover I think, so it meets the minimum criteria.
I seem to have a few around here I could give it a go with
Baushausler:
If you want to hit those DT210Tis for $25. today, count me in for two.
I'm honestly not certain if I would notice the difference between the 210 and 220 with my ring and ding ding ears :lmao:
Drivers and adaptors are ordered, 16 drivers and 16 adaptors!
We got both adaptors so lot's of experimenting to commence!
I have done it with Seleniums on a different PT waveguide, one of those I cited just above:So has anyone tried these with a tweeter plugged Large Advent system? Good bass and about a 1200hz crossover I think, so it meets the minimum criteria.
The Large Advent's are considered "keepers" by lots of forum members. I would love to see if the EconoWave top end wouldn't improve their sound. Bet it will!!
Please try them, and let us know.
BTW again. I just measured the EWG against a New Large Advent speaker and the flange is about .250" too wide to fit. This doesn't mean you can't do it. You would have to trim the flange and drill new mounting holes on the short sides. Not much of a compromise. I'll bet it would work really well, too.
Andyman, if you read this would you measure the front baffle width on a Utility Large Advent cabinet? I'm almost certain there's more than enough space for an EWG because the front rim is so much narrower.
