Sometimes people will ask if it's OK to route the baffles for flush mounted drivers in one of my loudspeaker designs, if that will help or hurt performance. I always tell them they can be routed or front mounted, that it's largely a matter of aesthetics. The tolerance of the crossover components and thermal shifts do more than a fraction of an inch offset, at least at the scale we're working with here, in the overlap region of 1kHz to 2kHz. And the diffraction edge is too small at these frequencies too. It's acoustically invisible.
I'd guess I was aiming at 1.2 kHz.OK. I found your crossover design for the BMS 4550 (and JBL 123A-1) in the "Interesting 60's speakers" thread. What are the crossover points? I didn't find that when reading through the thread.
Yes, that'll work, making towers of them. An additional cubic foot or so is all that is required, easily acquired in a plinth. From the BB6P models, just moving the baffle forward or adjusting the tuning isn't going to do much.Here's a wild-A idea for those who like the PE trap cab but think it is two small for the DC300: Build an extender-stand for it like Zilch did way back with the LE14 and increase the cabinet volume. You could match the angles of cut with the existing knock-down panels.
Or, you could be crazy and buy 4 trap cabs and make two enclosures out of them, sorta like member dc270 did with his homebrew Altec 19's.
Thank you for your suggestions again, Wayne. I'm not certain if cabinet edge overhangs are that big of an issue when using CD waveguides, even, but we're now in a position to measure and find out.Those of you that are using the PTF95HF might consider this. This allows your baffle to form part of the final flare, and the roundover smoothes the transition. You can keep the woofer close to the tweeter, closer than a larger horn will allow. Sort of lets you have your cake and eat it too.
The QSC website parts store.... :yes:where can one purchase the QSC waveguide?
The only other "Official" waveguide is the 6" square JBL PT at this point, with the 8" square PT and QSC pending, though we have used the larger Dayton elliptical, 18-Sound XT120 and XT1086, and JBL OASR in other projects and threads here on AK. The JBL PRX horn also appears workable:Is there a list of alternate waveguides that work with the D220ti with little or no change to the original crossover? I know I could use the original JBL or the QSC (if I get the bolt on D220ti).
Zilch said:it's getting below 40 Hz nicely, if that's good enough.
O.K., we'll see how well I can tweak it today, then....That would be fine with me...![]()
Hey guys, I apologize if this is listed somewhere but I couldn't find it...
Itried my screw on 220ti with an adapter on the H290 that Wayne uses, it was fairly worthy to. Cant say enough about the little 220ti, for the price, it is amazing.I have done that and heard it, and it is worthy.
http://www.jblproservice.com/pdf/PRX Series/PRX512M.pdf
All of these require adjustments to the core eWave crossover.... :yes:
The Altec 511B sure seemed to work. That would imply that they Pyle PH714 should also work (same basic shape, just with better dispersion in the PH714).
Regards,
Gordon.
I will have to try that. i tried it with the altec 802 8G on the 511B, didnt sound as good as the crossover I already had in the A7. I only have the screw on 220 ti, so I'll have to use an adapter....
Russellc
Russellc
I second that. I am using Pyle PH612.And the Pyle! but its essentially the same deal as the JBL I guess
Regards,
Gordon.
Oops. You'd want the bolt-on for a 511. The adapter adds too much length to the throat. Might work, but I'd guess it'll change the response...
Regards,
Gordon.
I am looking at the adapter that PE sells and it looks like it could be modified to flush the driver to the flange face by tapping the threads farther toward the flange face and then relieving / the appropriate amount to allow the correct interface. Doable but APITA with correct tools required all to move the driver forward a few mm's - 3/8"...
But it is hard to believe that there is not an existing correctly engineered adapter out there that allows the driver to be flushed to the flange face....:yes:
Any body seen a good flush factory adapter?:scratch2:
