So there is an audible difference between a screw on type vs. bolt on type? Is it significant? Is it worth it to convert screw on to bolt on type?
Not saying this, rather, that the best approach is to use bolt-on drivers with bolt-on waveguides and thread-ons with thread-ons.
Don't know about audibility, but there are measureable differences between the performance of drivers with and without throat adapters of sufficient magnitude that my studies posted earlier in this thread suggested crossover modifications should be developed to correct for them. Instead, for the moment, we are pursuing adapting the basic eWave design to incorporate a bolt-on waveguide.
Since D220Ti is available in both bolt-on and thread-on versions, it is logical to try the less expensive standard eWave driver in its bolt-on variant as well as the DE250, and perhaps open up an additional economy option which some builders might desire to pursue.
I've been what-if-ing a large Advent project in my head for a while and thot ; What if a board about the same thickness as the grille posts, with a step-down to the woofer portion, was sealed to the upper baffle and the whole recut for the waveguide, close to the woof, to bring the waveguide forward. I suppose you could still move the woof to rearmount on the baffle if you thot you needed more offset. A grille could be nicely velcro'ed to the result.
Page back to my recent first look at the location of the forward axis of the standard eWaveguide in OLA. What does that suggest? I'm getting better at this, and can redo it, if warranted.
Insofar as the QSC waveguide is concerned, I am largely confirming Jack's observation that small differences in driver/waveguide offsets as occur with various 10" and 12" woofers do not alter the "tilt" of the forward lobe sufficiently to warrant additional intervention in the basic eWave design. A 4.55° upward "tilt" of the forward axis is not a bad thing; for reference, 4430 is tilted 8° - 10° upward, depending upon which white paper we cite.
will the Dayton 12" round or other cheap waveguide along with Selenium 220 reach my 15TBX40 woofers? -or should I just go 3-way with cone mid and slot-horn tweeter?
It is generally recognized that a crossover in the range of 1.2 kHz or lower is required to match 90° horizontal directivity with a 15" woofer, and the situation is worsened with using an axisymmetric waveguide requiring a minimum 13.5" center distance. D220Ti don't play that, basically, and no one has measured the polar response of any of the Dayton waveguides, cheap or otherwise, to assess their applicability or suitability for use in these designs.
My basic advice remains the same: for EconoWave design, stay with the documented eWave program. If you want to do something else, that's fine, too, but you'll have to rely upon other resources such as Wayne Parham's studies and developed products for guidance.... :yes:
