I routinely use BMS 4552nd with throat adapters, but that requires different filters. Jack's working with the 4540Nd, but that and the small JBL drivers 2408H and 2414H are best suited for use at higher crossover frequencies.To the rest of you, what option is there for us with the JBL 1" screw on waveguide in the higher end department? I see the DE250 and BMS drivers are bolt on. I have adapters, but these cause problems? Can I hack the end off the waveguide and epoxy my bolt on adapter to them?
Even though it uses the same diaphragm as D220Ti, I consider D2500Ti-Nd an upgrade. It's time that somebody worked through dusting them with Aquaplas.
Otherwise, you can see our basic approach to bolt-on drivers has been alternative waveguides. It's also possible to install a bolt-on flange to the standard eWave ones, but no experimenter has proven a geometry for accomplishing that yet....
