Spectrum77
The pics of the front panel show a small screw a couple of inches below the woofer. This screw goes into the end of the front to back 2x4 brace. This brace would have to be removed, as the wave guide covers it by an inch or two. Even with the brace removed, the guide could not be movedany closer to the mid-bass driver, as it also interferes with the bottom two ports.
G'day Russell- just another option for you- it's possible to remove the 2X4 and replace it with two braces glued and screwed to the baffle at each of the triangular points formed by the waveguide, woofer and port. No problems with this at all. Waveguide could be positioned very close to woofer.
