Sounds like the Peerless woofer may have a roll-off of its own, in the crossover region.
With the original Advent crossover (first order), there may not have been enough total phase shift to cause cancellation between the new woofer and the tweeter. With the E-wave crossover, being second order, there's an additional 45 degrees of phase shift... which might be enough to cause a cancellation.
You have two choices- either go back to a first order lowpass (single coil, with or without a zobel) and tune it to work with the Ewave highpass, or tune the Ewave lowpass to work with your woofer. Without measurements on the Peerless woofer, it's hard to say which will work better. A frequency response plot of JUST the woofer in the enclosure, with NO crossover (woofer connected directly to source) would help a lot in diagnosing your problem further...
Regards,
Gordon.
Regards,
Gordon.
