bwaslo
Yup.Does it also share the metal insert of the Pyle unit?
Russellc
If you showed me either one alone I couldn't tell you which was which.
Russellc
Did you assemble that, or is it a page on their website?Hmmm....
"Smaller Advent" woofers?I have some of the small advent woofers that need new foam if you need a set.
Right. JBL 2226H isnt much cheaper. I paid around 200 for 2225H, and another 400 to recone to 2235H, so they sound like a bargain to me! I just cant make up my mind if I want 15 inch or 12 inch:scratch2:
Yes expensive compared to some of the more Econo boxes done here, but still Econo comparing what you end up with, and what its comparable to what's for sale on the open market ready made.
russellc
Mark,
I have a set of 15" Utahs out of Seeburgs that your welcome to play with and see if they'll work for you.
George
Nope, that's a screenshot from a PX email flyer I got this morning. Looks like you can view it online though: http://www.parts-express.com/eflyer..._content=Cannot+View&utm_campaign=email061710Did you assemble that, or is it a page on their website?
[If so, link us, please....]
I know exactly how you feel Craig. I have been doing the same thing with a set of JBL L100Ts. I used the same xover as you with Jack's mod of the resistor across the woofer for the 2214h. So far by far the biggest improvement has been removing that resistor. Really opened up the vocals. But as you noted it still sounds hollow.
I have been listening to this setup for a few days. It does many things very well. Dispersion is great. The drum set can be in the middle of the TV. Very clean and detailed mids and highs. Some harshness or roughness, but less than any other speaker in the house. May be something in the electronics.
Last night for a sanity check I played these speakers and the 901s without the Bose EQ so that the 901s are just playing mostly midrange. Now the 901s are a little more efficient but WOW. I hadn't realized how much was missing when doing AB comparisons.
I admit that I like a full, rich warm sound. Harshness or bright kill my ringing ears. While the Ewave has huge potential to be what I want this combo isn't there yet.
so what do you folks think of these from their "new" series
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-034
15" pro woofers
It doesnt even come close, to my ears. Something isnt right with the e'wave setup,
IMHO, or the original poster just prefers it for whatever reason, which is certainly their right.
Russellc
I'm not sure what else to try or to check. I've swapped crossovers (I built the pair) and they sound the same. I had the waveguide within a couple inches of the woofer (cabinet on its side). I tried moving the waveguide forward until its voicecoil was aligned with the woofer's. I'm pretty sure I swapped compression drivers. I took a lot of freq resp graphs with my dB meter and test tracks, but I have to do it on graph paper.. :drool:
As for sound preferences, I've always liked the dynamic, effortlessly loud sound of horns, even though they often had a colored sound, which I overlooked. These have have some of those horn colorations, but not too bad. But my real letdown was comparing the highs - for instance, on one well-recorded track, with the Advent I could immediately tell I was hearing a brushed cymbal and a tamborine, but on the econowave, it sounded like one instrument. I found that same effect on several different disks. This was true on and off-axis.
The vocal issue makes it seem as if the singer has taken 3 steps back. I really tried to discern if I was just used to the Advent's midrange, but it has to be right - there are too many places where I can understand the words with the Advent and can't with the econowave - and it doesn't seem right that unintelligible should be correct... but I'm 50 and maybe I need a vocal boost? :scratch2:
I really wanted these waveguides to work out, maybe I will leave the Advents intact and build the DC300 standard ewave and then do a shootout?![]()
Rob is going eWave???Good to know, as I have been waiting for the Peavey to be available. I just looked for it today and only see the Dayton. Guess I can order my parts now.
Rob
I missed it, what components and cabs are you going to use?That 10 dB rise from 1KHz to 2Khz might just be a trouble maker for you, since it is centered around the crossover frequency.
But why not give them a try? A simple Zobel may make them super.
Most of what's been built with extended bass has used vintage woofers. In new ones, eWavers like the DC300. Much of what I've been doing lately has been higher efficiency with pro drivers for use with subs.Hey Zilch! What do you think I should do for a new e-wave woofer to have the maximum bass extension (in a custom cabinet of whatever size necessary), for around $110/woof or so?
Alright, that was exactly my impression, but it seemed more than a little bit likely I missed something. The pro drivers plus sub approach makes a lot of sense, but not something that works for me at the moment. I know it is pushing some limits to have this sort of 2-way go deep without messing everything else up, but I'm willing to experiment on a promising suggestion... P.S. I have no shortage of power.Most of what's been built with extended bass has used vintage woofers. In new ones, eWavers like the DC300. Much of what I've been doing lately has been higher efficiency with pro drivers for use with subs.
