truth seeker
Member
We will show PE within a month that they want to source the QSC 152i.
anybody ever ewave a set of cornwalls? I just picked up a set of cornwall cabinets with the 15" klipsch woofers in them. Grills are gone and cabs have had some minor cosmetic repairs done. I already have the entire ewave xover,horn,driver ready to go. If I am lucky, I'll get it installed tonight.
Can't wait!
Pics to follow.
Mark
I'm canceling econowaving my Advents for now. For the past month I set up the right Advent as the econowave and the left Advent remained stock (except both have been updated with a Peerless 8" woofer). So far I've tried the generic econowave crossover built as specified, then modified by removing the low pass shunt cap, and then bypassing the low pass completely, each setup tried with both tweeter polarities and numerous L-pad adjustments. Using the same mono signal for both, and switching between left and right, the econowaved version never has the natural presence in vocals that the stock one has. I swapped woofers to verify they were the same. Also the highs are never as natural, which really disappointed me, as I wanted to love the waveguides. Its hard for me to believe that these old Advent tweeters are superior. I think there is more work to be done in the econowave crossover, and its currently beyond my abilities to do it. Luckily I didn't cut on the cabinets yet. I'll keep the PH612/D220Ti boxed up, and if a woofer/crossover combo for them is tested and proven to sound great, I'll put them with that.
This has been a learning experience - a few years ago I would have just built the econowaves without comparing them to the originals, and would have convinced myself that they were better.
No one has yet verified, but it appears to be a "Yes."
CraigB: are you listening off axis or on? What caps are you using in the crossover?
I've heard the small Advent tweeter and was impressed but didn't think it compared to the Selenium220/PT Waveguide.
I'd cut a set up in a heartbeat.
I have some of the small advent woofers that need new foam if you need a set.
I'm well familiar with the Large Advents, having owned at least 5 pairs. I've Ewaved OLAs (Make Magazine issue #20), ULAs and NLAs and each time I felt the sound was an improvement over the stock tweeter. I'm a big fan of the Advent woofer but I just don't like the sound of the stock tweeter nearly as well. For me the improved dispersion of a waveguide was a big plus, but that's installation dependent. I have 8 Seleniums on hand and a bunch of waveguides on order so I'll probably be doing a few more conversions.
2 people have told me that ewaves seemed to have a poorer 'soundstage' than conventional horn speakers. I think this is probably due to a wide listening window versus many horns' narrow beam and locked-in seating position.
Sell those Cornwall woofers and get some Lambda's!
There's a set of each here (the PH from MCM and the H from Parts Express), they are virtual clones, look to be off the same mold. The MCM looks a (very) little shiny-er on the outside and has a bit larger set of chips out in the throat where it looks like it was broken from the mold, but probably just unit-unit variations. Both measured the same response, within a half dB or so, when connected to the Selenium 220Di.
On and off-axis, the vocal problem remains. This Advent tweeter is a small fabric dome. I don't have the original Advent woofers anymore...
You get a lot of woofer for 600.00/pr considering they are on the same or higher level (personally, I find them better) than TAD TD1601s at 1k each. I'm not sure I know of another legitimate contender in terms of performance outside of the TAD.
