Be sure to compliment me on my cabinet work
I tried to test out my driver plan today with drivers mounted on a cardboard box (using the box from the PE trap cabinet in fact- what are all those wood things inside for, BTW?
). For crossover, I just tack-soldered together the components for the basic eWave crossover for <95dB SPL (looks like I should have used the one for >95, though, ran out of gas on the L-pad).
I wanted to do outdoor measurements, but showers are predicted for all day today. So, the family room it is. I put a thin wire from one of the waveguide mounting holes to the mic clamp and used it so all measurements are 1 meter from that point, and eyeballed the angles. The "dBr" values shown are the correct dBSPL sensitivities for 2.83V. See the photo for the meticulous lab setup.
The results are of dubious value, IMO, but here they are for anyone who wants to try interpreting. I think the floppy cardboard box, with unsealed holes even, is resonating like mad, particularly around 1kHz (unfortunately right around where I'm most interested). So the directivity plots aren't great.
First two plots are with the drivers all flush mounted, horizontals (0, 22, 45, 67 degrees), then as if equalized to flat on-axis; next two are verticals (0, 12, 22, 45 degrees).
(In a post to follow, because of limited uploads allowed --) Third two are with the waveguide pulled forward about 3inches to roughly align the voicecoils. Horizontals; Horizontals as if eqd; Verticals; Verticals as if eqd/
No smoothing applied to any of the curves, windowing is set so that anything below about 700Hz is dubious. If you squint your eyes (and maybe wish a little), you can see the directivity working below the crossover points from the 4 woofers. To get around the boxy wall resonances, I'll probably have to commit to wood and bracing. I think I'll want to go outside, too, for measurements, since 1 meter isn't much distance for vertical measurements on drivers that span over 18 inches.
Here they are:
