skywave-rider
Slumming in Akihabara
Thanks Gordon.
I just ordered Surround Sound from Holman:
http://stereophile.com/reference/408surrbook/
If the forward axis is between the 2 large vertical woofers, not in a 2.5 setup, it might be trouble for an EWave system since we're trying to maintain tight spacing between the HF and LF on the baffle. But with smaller woofers, like you say, this could be real cool to narrow their pattern. However, I guess with woofer pairs, the choice is either narrowing the vert or the horizontal. A quad of small woofers would be ideal to match small woofers to whatever pattern comes from the WG at crossover?????
Great food for thought. Thanks again Gordon.:thmbsp:
I'd add another tidbit to this- I'd recommend a read of Tomlinson Holman's treatises on why many of the original THX movie theater speakers used dual woofers. He's using the same "pattern narrowing" technique- only compounding it, by using two woofers STACKED, to cause the patter to narrow TWICE as fast in the vertical direction as the horizontal direction. This causes a reasonably "rectangular" pattern, which closely matches the patter of many horn drivers.
A pair of 10" or 12" drivers can work well for this, using an E-wave horn, by my calculations... they should have "closed down" to around 40-50 degrees vertical dispersion by no higher than 1.8KHz or so (lower for the dual 12s). Holman originally specified dual 15" woofers with a 500-800 Hz crossover point... there's no reason we can't use dual smaller woofers with the one-octave-higher crossover point of the Ewave...
Regards,
Gordon.
