That's the standard eWave crossover, and it should balance easily with DQ-10 woofers, which are the same as in large Advents, basically, used with DE10 compression drivers.
What are those woofers, actually?
What did you do for the 12uF in the lowpass there? Is that a 10uF electrolytic in parallel with a 2uF film cap? A BIPOLAR electrolytic?
Put the correct 12uF MPP cap in there and see if it still sounds like ass....
Yep, that is the cap set up we have. OK, so that is one thing to look at. I am 240 miles from Dell and when I go up next, I want to have as many bases covered as posible. So, if replacing the cap does not do the trick, what else can I look at, high comp wise?
Here is what GordonW wrote about the woofers
"Those are made by Credence Speaker Corporation... the OTHER speaker company from Kentucky. Made in the 35th week of 1993, so they're relatively recent, by "vintage" standards.
They look as lot like Speakerlab drivers (especially the cone, rubber surround and dustcap). However, I do not know if Credence ever built Speakerlab drivers...
I'd be inclined to try the OLA woofers. Those Credence woofers probably want a larger box than the OLA or Dahlquist woofers would use, for optimal response linearity.
Regards,
Gordon. "
It seems that Ross and I did a WT3 sweep on them but will have to check with Ross.
