@z-adamson You've summarized my points fairly well.So the QSC152i does not perform any better than the JBL 6x12 at low frequency. And you don't know why Zilch used the QSC.
MTG gets different test results with a Celestion driver on the 6x12 JBL than folks here using the same 6x12 with a D220ti.
MTG gets different test results than EarlK with the 8x8 JBL guide, again, using different drivers.
It's possible that the 8x8 is a better choice than the 6x12 w/ the D220ti. The D220ti seems less than ideal for the 6x12.
Earlk has a simulated design for a JBK driver on the 6x12, but it's untested.
Trying to figure out what you are trying to say here with all of this. Different people get different test results when testing different drivers on the same waveguide. That sounds like a given. You don't know why Zilch used the QSC guide. Well, nobody else does either. He didn't explain here on AK. Earlk's simulated designs are untested and thus need to be tested. That's a given too. The 6x12 JBL guide is an excellent choice with the right driver. But isn't ANY well designed waveguide an excellent choice with the right driver and not such a good choice with the wrong driver? That sounds like a given too.
Sincere questions and comments here. Just trying to follow what you are saying.
My response was to the member wanting to do a design with the NLA QSC152i guide, which I happen
to have, and always thought MUST have better LF than the JBL 6X12, this was the first time that I actually
looked at the numbers and I'll have to look again to confirm but it doesn't look that much better than the
real JBL 6X12" matched to a good driver. It doesn't seem possible with the QSC152i being so much larger
than the JBL, very strange, I'm guessing that I missed something.
Edit: Looking at the QSC152i WG again, it is 14" wide as compared to 12" for the JBL, not a huge difference
and it does have a bit better LF response. It is much larger in height at 10" vs. 6" for the JBL.
I was going to also suggest the JBL 8x8" which, I think with the D220Ti
has very good LF response, but also something new to me, is that with the Celestion driver that MTG used
the JBL 8x8 shows a less good LF response. I may be repeating myself but I just learned a few of these points
on the day that I made that last post. There's so much data it's very difficult to figure this all out.
I'm fairly new to horns and WGs and am learning more and more that horn to driver matching is very important.
I'd like to make some sense of it but so far, I don't have any general guidelines.
I should probably add the QSC152i guide and the JBL 8X8 to the thread comparing mostly roughly 6x12" guides with regard to pattern:
JBL 6X12 Clone Waveguide, Eminence H290S , Pi H290C and Others Compared
The Pi Speakers H290C Waveguide is a variation on the Eminence H290 WG with the primary difference being that the Eminence is close to an OS taper and the H290C makes it true OS. The differences are described in this thread provided by @safebet ...
audiokarma.org
