Good call, it sure does, and the DE10 is still listed at PE as backordered at more than twice the price.
I wonder how the DE10 performed.
Zaph tested my own DE10s mounted on the ME10 horns back in 2008, you can see the results on his site.
I have since moved on to the JBL 2408H mounted on the JBL 6x6 PT waveguide, better top end. For the past 7 years I have been running my old Seas 27TDFC on a SEOS 8, all mated to a B&C 8PS21 since 2008.
I'm planning to build another 2 way in the near future using the JBL 2408H and Aura NS6 to use as desk speakers.
Zaph's DE10 measurements are under his tidbits, use CTRL-F search with DE10 to find his comments and graphs:
Discussion in this thread: https://audiokarma.org/forums/index...llaborative-econowave-speaker.150939/page-335
DE10 and SB 25CD-P are not exactly the same, DE10 has an aluminum VC former, SB is film of some type,
otherwise seem very similar.
JBL PT-H95HF and PT-H95HF-1 12x12" WG 90x50 degree, 1.5" driver
Another big JBL WG, as I said I didn't follow this thread for many years and this was probably discussed
but the PT-H95HF and dash 1 versions are 12" by 12" that looks to be similar to the M2 WG that is rather
expensive, this takes a 1.5" driver. It has a 90x50 pattern and is used in this large system PD-595
as an example: https://www.pssl.com/products/jbl-pd595-15-inch-2-way-full-range-speaker
JBL .pdf doc discussing this guide: https://jblpro.com/en/site_elements/tech-note-progressive-transitiontm-pt-waveguides
In contrast the ELX is 12x8" but seems to be a much more basic design, the clone is at least cheap and it takes a 1" driver.
@300Z How do you like the JBL 2408H CD? Have you compared them to the 2414H-C?
I like it a lot, it has better top end extension compared to the DE10 and it's even more efficient, FR needed a little more work to smooth it out but I use a MiniDSP, so that's not a problem, in a passive system it would need more components to get a smooth response, but I really like it.
I have not personally used the 2414H-C, but have tested the 2414H and 2414H-1, they're a smaller driver, it wasn't very happy playing low in the PA boxes I tested. In a home setup it might be ok, but I wouldn't use it bellow 2-2.5khz depending on the horn.
HUGE JBL 365359-001-2384 Waveguide, 1.5" entry, 90deg H +30/-20deg Vertical, it looks to be 30" wide:
I mentioned here that we visited Audio Classics and heard the HUGE Klipsch Jubilee speakers:
I wondered where one might get a horn that large if they wanted to do a DIY/econo Jubilee and didn't
think anything would surface for it.
It is used in the JBL 4722 Screen Array Cinema system XO at 800Hz and 630Hz in the -N version:
.pdf https://jblpro.com/en-US/site_elements/4722-spec-sheet
I don't have room for anything this large but it could be interesting for someone who has room or a barn, church, school.
I compared the EV ELX112 WG clone to several others here, data from MTG of course:
Wondering how low this can be crossed, it depends on the horn taper, the EV XO is 1.7 KHz
but this might be for power handling reasons - not sure:
Those systems use a 35mm diameter voice coil compression driver. I'd tend to agree it's for power handling reasons.
I've always aimed for 44mm voice coil CD's for my 12 and 15" woofer builds so I can cross a bit lower. Especially for 15's that would be beaming by 1.7khz which will negatively affect the pattern through the crossover region.
What really matters with any driver is the volume displacement which is the surface area times Xmax
and the Fc of the driver which will start a 12 dB/oct rolloff. Though there is probably more to it since
the JBL 2414H-C driver has a fairly high Fc but plays flat below it.
As far as volume displacement goes, nearly all 1" dome tweeters without a WG will easily cross at 2K
second order, so with what? 10dB of horn gain they should go significantly lower or louder.
Does anyone know how much gain these WGs provide? I threw 10 dB out here as a guess.
Another reference point is that the 1.5" AR3a dome midrange is crossed at 500 Hz 2nd order without
a problem, SPL is limited I'm sure as compared to PA use but for home use a 1.5" CD with decent
volume displacement on a good size WG should go quite low.
I measured Xmax on the D220Ti and from memory it was underhung with generous Xmax, but I believe
that others have much less, if not equal hung coils for 0 linear Xmax. I have to confirm this.
Question, If I open up a bunch of CD s to measure coil and gap height do I have to worry about
ferro fluid loss or anything to do with it? How does one make sure that it goes back together correctly?
Most CDs I've opened don't use ferro fluid, the only ones I have seen it in were junk Pyle brand. However you do have to be careful on the reassembly, some drivers are sensitive to how the back plate is seated and the screws tightened/torqued and will result in resonances and higher distortion if not done correctly. Generally I try to apply slow equal pressure back and forth on each screw to the back plate is tightened evenly. Some have nice gaskets so everything is clamped well but it's quite a headache when you need to pull one apart or loosen and re-torque the screws a dozen times to find the right combination that results in a distortion/buzz free sweep. I've even had brand new CD's where this had to be done.
Thanks, I do have the JBL 2414 that does have ferro fluid, but maybe not the rest.
All that about torque reminds me of repairing dome tweeters and mids in the 70s that didn't
have centering pins. I don't think I'd want to use drivers that are so fidgety, a good drop of
the enclosure might throw them off.
I remember applying a test tone usually around resonance, and tapping the dome, up/down
right left until there was no buzz, tighten, try again.
Hi folks, is this still the recommended parts-list for the Econowave Standard?
Everything except for L2 is still available at Parts Express!
But a near-identical spec L2 has been added in red text below, with the original crossed out in black.
All parts & links from this list are posted below:
Jantzen Audio 0.80mH 20 AWG Air Core Inductor Crossover Coil
Part #255-044
$7
Dayton Audio IC184 4.0mH 18 AWG Laminated Iron Core Inductor
Part #257-662 (instead of EOL 266-562)
$9
Dayton Audio DMPC-3.3 3.3uF 250V Polypropylene Capacitor
Part #027-420
$2
Dayton Audio DMPC-10 10uF 250V Polypropylene Capacitor
Part #027-428
$5
Dayton Audio DMPC-0.47 0.47uF 250V Polypropylene Capacitor
Part #027-406
$1
Dayton Audio DNR-30 30 Ohm 10W Precision Audio Grade Resistor
Part #004-30
$2
Dayton Audio DNR-16 16 Ohm 10W Precision Audio Grade Resistor
Part #004-16
$2
Parts Express Speaker L-Pad Attenuator 50W Mono 1" Shaft 8 Ohm
Part #260-255
$14
Selenium D220Ti 1" Titanium Horn Driver 8 Ohm 1-3/8"-18
Part #264-270
$80
Dayton Audio H6512 6-1/2" x 12" Waveguide 1-3/8"- 18 TPI
Part #270-318
$19
Dayton Audio DC300-8 12" Classic Woofer
Part #295-320
$60
$201 (per speaker)
lol originally only$126 when Zilch first created the list
L1 is good to go. Jack designed L2's mounting hardware for Erse's standard iron core inductor using 4 mounting bolts. Erse's Super Q mounting hardware consists of 2 bolts and physically occupies the same PCB real estate so that might be a more stable fit with minimal alteration to the existing Econowave PCB. Basically drill two holes and you're good to go.
Here's the updated LE14A Econowave BOM including Rational35's inductor suggestions:
C1: Dayton Audio DMPC-4.7 4.7uF 250V Polypropylene Capacitor
Part # 027-422
C2: Dayton Audio DMPC-15 15uF 250V Polypropylene Capacitor
Part # 027-432
C3: Dayton Audio DMPC-1.5 1.5uF 250V Polypropylene Capacitor
Part # 027-412
L1: Dayton Audio 0.60mH 20 AWG Air Core Inductor Crossover Coil
Part # 257-040
L2: ERSE Super Q 2.0mH 16 AWG 500W Inductor Crossover Coil
Part # 266-904 (or if you aren't using Zilch's PCBs: Jantzen 5811 2.0mH 13 AWG P-Core Inductor, Part # 255-157)
R1: Dayton Audio DNR-16 16 Ohm 10W Precision Audio Grade Resistor
Part # 004-16
R2: Dayton Audio DNR-25 25 Ohm 10W Precision Audio Grade Resistor
Part # 004-25
LPad: L-Pad 50W Mono 1" Shaft 8 Ohm
Part # 260-255
Binding posts: Dayton Audio BPA-38SN HD Binding Post Pair Satin Nickel
Part # 091-1247
Waveguide: Dayton Audio H6512 6-1/2" x 12" Waveguide 1-3/8"- 18 TPI -
Part # 270-318
Compression driver: Selenium D220Ti 1" Titanium Horn Driver 8 Ohm 1-3/8"-18 Part # 264-270
Hi,
I'm just wondering if there are any other alternatives I can use for the 2.0mH 0.143 DCR inductor instead of
I'm in Australia and struggling to find these parts.
I found these https://speakerbug.com.au/index.php?route=product/product&path=18_45&product_id=748
Jantzen P-Core 2mH 17AWG​
They have a DCR of 0.18. Is that okay in the LE14A econowave schematic?
I can't seem to find anywhere locally that stocks Jantzen 5811.
Thanks
That one should be fine to use.
Also the info in that quote is not correct, the Erse Super-Q inductor is almost double the size of the standard Erse I-core and will not fit on the standard PCB.
