@RogerA , another one to look at, with all parts currently available is the SR Compact. I like that PA310 woofer.I understand not wanting to start from scratch because it's helpful to work from proven designs. Maybe you can tell us which of the prior projects (where not all parts are readily available) interested you and why. High efficiency usually comes with a sacrifice on bass if not built with an appropriately large enclosure.
A build I have been happy with is the Econowave HO.
Flex Your PCD Mettle: - Techtalk Speaker Building, Audio, Video Discussion Forum
Want a second or third opinion about your speaker cabinet design or other audio related problem? Post your question or comment on the Technical Discussion Board. Hundreds of technicians, engineers, and hobbyists, nationwide read and discuss electronics related questions each week. We welcome...techtalk.parts-express.com
It has clarity and efficiency in spades but no deep bass. All components are still available as new with the exception of the QSC152 waveguide. If that's a path you want to pursue you could begin inquiries and may find someone with spares that they're willing to part with.
There's a lot of folks here ready to help guide you.
And as @safebet comments, the higher efficiency pro woofers benefit from some subwoofer help, generally. @RogerA your comment about wanting "full bass" makes me immediately think of the Standard Econowave. It isn't so high efficiency as you are asking but I think the bass is fun and engaging with that set up. I have not listened to the Standard Econowave on a tube amp but I should try that. I loaned my Standards to someone for a demo. I expect to have them back soon and I'll give them a listen on a tube amp (current working tube amp is a Glow Audio Amp Two push-pull EL84). If you are close to Michigan, you are welcome to give mine a listen.
Smiley
