Adding a 35 gram mass ring (as used in the JBL 2235) under the dust cap, will make a 2226 go down to 28Hz, in a 6.5 cubic foot vented box, tuned to 27Hz. At least that's what BassBox says, when I simmed it with that mod to the woofer. Sensitivity at 2.83V is still over 94dB, and sensitivity at one watt, is just over 92dB. The 2226 will not power-compress significantly at anything under 150 watts, so that's close to 114dB output capacity, with unencumbered dynamics, from a SINGLE cabinet. And the midrange response of the 2226 is almost ruler flat- it only peaks about 2dB just before upper rolloff, compared to other woofers that sometimes peak 10dB or more.
That could be spectacular.
Regards,
Gordon.
