Oops, I typed R701 but it was R707 that I was looking at to ask about the diff pair.I didn't say anything about R701. What I said, was that it was R707 that had burned up (1k @ 1/4W). I then said, that I had recapped the board, and that I was well aware that the polarity markings on the board are incorrect for C701. I will get additional readings this morning. I want to re-iterate that there is +38 VDC on both of the PR coil terminals. Yes, I would say that there is no negative voltage at the relay coil. This has been the problem all along, but why?
R703 is 33K on the schematic and in the parts list. Even if it connected to 40 volts plus or minus, it wouldn't smoke. You measured near zero volts at the base of Q701 so is that resistor the one you think or is it really connected there? Q701's base, if shorted to the collector, and so at -40V would smoke a 33 ohm though. But that transistor would be through! Something's not connected as it should be regardless is my suspicion.
The base of Q703 is most likely due to the output of the amp being at a substantial positive voltage. I bet it is fine and a simple diode test will verify that. That voltage is due to the feedback path via R719.
