I am somewhat concerned about pulling the one output transistor (Q711) and energizing the unit. I have never done that before. I did pull Q711 and tested it with the DCA55 tester, (this is the third time I have done so). It tests good as it always has. I somewhat understand your concern regarding Q711 being shorted internally, but really, wouldn't that show up with the DCA 55 tester?? I think that is highly unlikely that this transistor is bad. All four of them have been tested and re-tested as GOOD.
I pulled Q715 and Q717. They both tested good. I re-installed them.
While I was inspecting the solder joints and the components themselves. As I said, initially I recapped all of the electrolytics on this board. What I found on visual inspection, was that C705 (47uF @ 50V), appeared visually swollen. Then I remembered that it was Q705 that I had found failed earlier on, and I surmise that whatever event took out Q705, may have taken C705 with it. I replaced it again, with a 47uF @ 63 VDC. I am starting to wonder if maybe diodes Q738 through Q740, and Q749 could be affecting things. They are all identified as WO6, which according to others, can be replaced with a 1N4004. I have not pulled them to test them.
I took ECB readings on Q713 at power. E 37.65 VDC C -38.48 VDC B 36.80 VDC
I have not re-energized the unit since replacing the C705. The current status is that I have the filter caps and bracket hanging, and the diode mounting plate as well. I feel a little squeamish about powering up with that arrangement. Last night I left them that way in case I had to pull something else to test.
