2385 reconnect PS00 to P400 pin question
Let's start by measuring some transistor voltages on the P200 board. I don't know if you can get to it easily, but maybe we can get a clue as to what is going on.
I think the P200 board is located here?
Also, make sure there is a wire connected to J201.
Before i check voltages i have a question if you dont mind, on the P200 board only Q201 and Q204 read voltages both ways on diode test unit off, all others only show voltage drop one way, Is 201 and 204 different?
Sometimes it's hard to test transistors in circuit. Which junction did you test on Q201, Q204 where you read voltages in both directions?
multimeter on diode test, unit unplugged Q201 black probe on base red on e = 1.1 red on c= 1.2 Red on base , black on e=.743 black on c- .731 Q204 Black on base red on c=.951 red on e-1.164 Red on base black on c=.717 red on e .729
Attached photo, transistor values, multimeter on DC Transistor Q211 E and C values are reversed, copied it wrong
Got it, thanks. I copied your measurements onto the schematic and most look close except Q209, Q210. (see schematic below)
The schematic voltages shown in ( ) are when an FM stereo station is tuned-in.
We need to figure out the function of Q209 & Q210 to see if that is a problem.
I don't know, not familiar enough with the board to follow the functions.
We can try to measure some voltages on Q301 (FM Stereo Demodulator) to see if it looks OK. It is an HA1156 (see datasheet).
Maybe we will find something.
Measured Q301 voltages on schematic. What looks suspicious is that Q301 pin 8 has the same voltage as the adjacent pin 9, 2.3v.
I think pin 8 is the output for the 1st IF and pin 9 is the input for the 2nd IF block.
Do you have a capacitance tester or does you DMM measure capacitance?
Some cap testers will let you measure capacitance in circuit, but if you don't have one and your DMM can measure capacitance.
Try and remove one lead of C307 then measure the capacitance to make sure it is not shorted.
Also, examine the board trace to make sure there is not a solder bridge between pins 8 & 9.
I have already tested C 307 in circuit, it is not shorted and it reads 1 or just over in the board, if you need it tested out of the board i will need to remove board, does it make sense to remove the variable cap and test it ? removed C307 from board ,read 220,5 nf with esr tester seems to be non polar
Just want your thought on this, i will take readings from the 5 transistors on the buffering board in the morning,
Q209 emitter & Q210 collector voltages look wrong, check those first.
I checked resistors connecting to Q209 and Q210, found 2 that are way off but havnt removed them yet R260=12k, R262=22k, R263=560k, R264=2.2k, R265=2.2k, R259=5.6 Still looking for R301. Should i be removing the ones that are way off to test again?
Looks like R301 is on the schematic, but not on the board layout... maybe a design change. Q210E is directly connected to C249.
To test some of those resistors, it might be necessary to unsolder one resitor lead then measure the resistance.
First, check the resistor color code to see if the resistor value matches what is on the schematic. Sometimes there is a design change and a different resistor is substituted.
Compare your board traces to the layout in the SM. Does yours match?
There seems to be some other changes. R301 and C249 are connected in series, but the order is reversed.
C249 listed 47 uf reads 64.5 uf out of the board, Cap 248 lists at 22uf reads 27.6 uf R259 listed 5.6k reads 5.5 k, R262 lists 22k reads 22k, R264 lists 2.2k reads 2.2k R301 lists 2.6 k reads 2.6k All resistors colors match listed values.
I guess that I am out of ideas. If you could use your oscilloscope, you might be able to see if he 19kHz is there and that the tuner is working. I'm not sure how else to proceed.
If we revisit this test, you might want to remove Q201 and Q204 and test.
  • Red on Q201 base, Black on Q201 emitter - should read 0.45 to 0.9v. Swap leads and it should read OL.
  • Red on Q201 base, Black on Q201 collector - should see a reading. Swap leads and it should read OL.
  • Red on collector, Black on emitter - should be OL, reverse leads and should still read OL.
  • Same test with Q204.
Saddly they both checked out perfect, I replaced the C249 with a 47 uf 16 vlt. with esr it was 68.5 uf
I'm out of ideas. Maybe your FM tuner needs alignment, but I'm not the one to instruct you on how to do it, sorry. :no:
Thanks for all of your help with this. I will have the tuner checked with oscilloscope, also im going to try freeze spray on components while on to see if i can get a change. pete
