I don't think so. This is from the 2385 Handbook of Instructions:
You can check it with your Wave radio in Aux input by only plugging in the L channel, then you should hear it from both speakers when you select "L" and not hear anything when you select "R". If you put it in "REVERSE" the sound from the "L" channel should move to the "R". When you put it in "L+R" the signals will be added (but you only have the L channel plugged in, but you will hear it on both L and R.
Here's a test that you can try:
- Play your Wave radio or a record.
- Use the MODE switch to select the L channel. You should hear the same mono out of both speakers. Do they both sound the same? Or are they both bad?
- Now select the R channel on the MODE switch. You should hear the same mono out of both speakers. Do they both sound the same? Are they both good or bad?
