When starting up the receiver the speaker relay LN01 is not engaging. Maybe i have bad info but i was told if it is not engaging you cannot measure mv at speaker terminals but you can at the resistors on each amp.What exactly are you trying to do? Are you trying to set the DC offset?
If you are measuring DC Offset, and adjusting R729, then you need to attach your DMM to measure mV across the speaker terminals and adjust to 0v.
Is that what you did?
I set my meter on MV, DC Black probe chassis, Red probe one side of R786, using trimmer R730 set to 0mv
Black probe chassis, Red probe on one side of R785, using trimmer no affect MV floats from 135 to 59 up and down
