I pulled the resistor and tested. 69ohms
OK I replaced RN02 with 100ohm RN06 with 47k ( you state 10k but the chart you sent me states 47k) please correct me if i am wrongRN02 = 100 Ohms, you measured 69 Ohms out of circuit. That's a 30% tolerance.
PL says it should be a 5% tolerance, so the minimum resistance is 95 Ohms.
Might as well check RN06 = 10k and RN01 = 220k to see if they also have a problem.
Pins are the same and specs were confirmed by electronics supplier, owner is an electrical engineerRN06: Schematic shows 10k, PL shows 47k. What was installed originally? Replace it with the same.
RN01: 220k
RN02: 100 Ohm
I don't have a datasheet on the 2SC667. Are the pins in the same order as the 2SD667 (ECB)? Are they similar in specifications?
Better photo, RN02 97.9 ohmCompare your resistors the one on the internet.
- RN03 = Red-Red-Org = 22k
- RN04 = Red-Red-Org = 22k
- RN06 = Brn-Blk-Org = 10k
- RN01 = Red-Red-Yel = 220k
Colors confirmed to be as per your postCompare your resistors the one on the internet.
I thought that you changed it to 47k?OK I replaced RN02 with 100ohm RN06 with 47k ( you state 10k but the chart you sent me states 47k) please correct me if i am wrong
Moved it back to 10 k, as you suggested the old one was 10 k . Either way something is cutting off the power after soft start.I thought that you changed it to 47k?
I'm not so sure about your "electrical engineer" electronics supplier owner. I think that the only common thing is they are both NPN transistors.Pins are the same and specs were confirmed by electronics supplier, owner is an electrical engineer
Yes, what do you want to test?Is there a way to test soft start relay?
After what I read I think I need to wait for the transistors I ordered. I don't want to turn the unit on if it can cause issues. Just strange because even with the original transistor, I would get voltage at the transistor and NP01 but both would have no voltage when the soft start relay engagesI'm not so sure about your "electrical engineer" electronics supplier owner. I think that the only common thing is they are both NPN transistors.
If you compare the specs for a 2SD667 (original) against what he sold you, a 2SC667 (replacement), you will see a BIG difference.
On the left are the specs for the 2SD667 and on the right, the 2SC667.
- The first thing to notice the difference in the max collector-base voltage: 120V vs 15V
- Next, the max collector current: 1A vs 0.03A
- Power dissipation: 900mW vs 120mW
- DC current gain: 60-320 vs 25
Hopefully you did not damage anything else in the circuit when you installed it.
Yes . the photo is the original transistor. Second photo replacementDo you have a transistor tester?
