I've never seen an Aragon closeup yet (only listened to a couple of them).. Maby @mondialfan can help?Speaking of rail voltage, how does one go about setting it? I'm only measuring 50v rails on my Aragons, should be 70v rails.
On second thought: are you sure your DMM is measuring correctly? Even by adjusting the voltage selector, as low as 50VDC shouldn't be able to achieve??Speaking of rail voltage, how does one go about setting it? I'm only measuring 50v rails on my Aragons, should be 70v rails.
Will Toshiba TTA1943/TTC5200 also work as replacement powertransistors over the original Toshiba 1302/3281?
Best regards
Thanks for reply. I see the TTA/TTC is rated at 150w pr unit, over 200w with the MJL....I wouldn't use them. On Semi has their own replacement for the Toshiba parts. On Semi MJL1302/MJL3281
It is a lot of value for quite small money, at least here in Denmark, where pricetags are almost half the pricing that "flows" on the internet from US market...lot of value for the price in this power amp.
Aragon series of amps, how do they power the speaker protection circuit??
Regards
Ok thanksIt is powered from the +75VDC rail.
@mondialfan is the speaker protection a simple relay that can be bought, or a bigger circuit?
From the pics it looks quite simple
