This thread seems to be the tome of Acurus Knowledge. Please let me know if I need to make a new thread.
Long story short, in the process of changing the electrolytics on one of the boards in one of my 200x5s I blew the output transistors. I am pretty confident that I blew more than that. I'm hoping that I can get some help on how I could have done this and how to go about repairing. I have one or more replacement parts for all the transistors on the board except the NPN/PNPs. I have some supposedly new old stock 2SC1302 and 2SC3281 coming from a USA seller on ebay... Hopefully they will be real.
So, short story long. I have three Gen 2 (oval faceplate) 200x5 amps, two of which are in active use in my home theater and one is a spare I picked up recently. I have five other acurus amps that I've re-capped the main filters with the recommended Kemets and added .1mfd panasonic bypass caps to without issue.
One of the channels in one of my in-use 200x5s started making a noise that sounds like wind on a mic without a windscreen. When I got the third 200x5 in, I swapped two of the boards from my in-use system with boards from the "new" amp. I wanted to take some time and go through and replace the two electrolytic caps, clean and re-apply heatsink compound, and re-bias each board, hoping to get another 20 years out of the "fleet". I also am adding .22mfd bypass caps in the provided locations on the +/- rails near the fuses. I would also like to add the 100mfd post fuse caps per Acurus design, however the boards are super cramped and I'm not confident about trying to stuff two additional large caps on the board. During this process I was hoping to fix whatever was causing the noise. I moved two boards over because when I couldn't remember which channel was making the noise after I took everything appart so I just swapped two of the boards over.
At this point in the process, I had disasembled the amp, removed the old main filter caps, cleaned and added snubber caps to the rectifier and re-installed the power supply. I checked it for proper voltage with a meter and all was well. I then took one of the boards that may have been making the noises from the old amp, desolderd the ground, desoldered the 10mfd input cap and replaced with a nichicon muse UES1V100MEM-ND 10mfd 35V bi-polar and replaced the 200mfd cap with a nichicon muse UES1V221MHM 220mfd 35V bi-polar. I checked both caps for shorts with a multimeter, both were fine. I then added the .22mfd 100V film bypass caps to CV1 and CV2. Again I used a meter to check my joints and they all seemed fine, or at least not shorted. At this point I re-greased the output transistors, added the mica insulators and re-attached to the heatsink. I was feeling pretty good because I really didn't mess with anything other than an input cap and some bypass caps. The only thing I was worried anbout was the 220mdf cap and that one seemed to have a good joints. I went ahead and connected the amp to the power rails and soldered the ground wire back in. At this point I powered the amp on and got no signal, not noise or hum...nothing. Fearing the worst I put my hand near the output transistors fearing they would be hot, they were room temp. I validated rail voltage was good, I put a tone generator on (laptop with USB audio output). I got nothing on the connected speaker. I had the amp running like this for quite a few mins, no sign of excessive heat from any components.
Not knowing what to do here I decided to use my scope to see how far into the circuit I was seeing a signal. I hooked one channel up to the RCA input and used a second channel to poke around the board. I had a clean copy of the signal on one side of the empty c11 solder pads. I wasnt able to locate it elsewhere and really wanted to get access to the bottom of the board.
This is where everything went to hell.
I thought, everything is running cool, I should be able to run the board off the heatsink so I can get access to probe the bottom of the board. I got a sheet of non-conductive plastic and put the board on the plastic outside the chassis. I had the amp on just a min or two and I felt heat and before I could kill power saw a spark from the neighborhood of the smaller to-220 transistors... All the output transistors and the to-220s were all rocket hot. Not a good feeling.
I ohmed out the 2SCXXXX transistors, the 1302s are dead short, the 3281s are short between two pins and .5 ohms between the other two. I'm just asuming all of those as well as all the TO-220 parts are bad at this point.
The board itself seems to be ok. I've attached pictures of the board immediately after all of this. I don't think I botched a joint, but perhaps there is something I don't know. I am suspicious of the 220mfd cap being a bi-polar. The original part seems to be a nichicon marked "NP" which I assumed mean "non-polar". The other Acurus amps seem to indicate a bi-polar part there. I don't see how the bypass caps could have caused this. I also don't understand how the fuses didn't blow before the output transistors blew. I am extremely confident that nothing was shorting. Perhaps there is something about not having the transistors mounted to the heatsinks?
I attached pictures of the aftermath. The one with the arrows indicate the joints I touched. The other joints that look touched are from heating of the components.
Please help me as these amps seem to be especially rare and I would like to get this one back together as well as get confident again on working through the other 24 channels worth of Acurus amps I have....
P.S. doing some tracing of the circuit, the topology seems a little closer to an A100 or DIA than an A200.
