KNielsen
Well-Known Member
@Doug Minderh wow, the noise issue aside, the aftermath is quite extreme... I really don't know after reading your findings where to address the problem so that your outputs will burn, besides from oscillation.
My first guess was a bad connection at the feedback (220uf), or just a tiny soldersplach that's almost invisible between the two solderpoints at this location that could bypass the cap or misdirected the signal??
Also it's a dual layer PCB, so maby one of the legs on the 220uf didn't make proper connection to the front layer copper if the cap moves just a bit when flipping the PCB ect ... This is possible, if when removing the old cap that the copper-insert in the PCB between the tracklayers leaves it's position together with the old cap... Check the old cap if this is a possibility, and if the insert had leaved together with the legs of the cap?? Personally I see duallayers where the designer choose frontlayer copper to a cap as a design flaw in terms of repairs afterwards. It can be tricky to remove enough solder to remove the cap without the insert follows. But often no problem......
At one point I also thought the possibility that you made an internal groundloop when applying signal and started probing, but normally the Zobel resistor will respond quite quickly if oscillation occurre and send magic smoke untill it burnes if one doesn't react fast and removed the source that courses the loop!
Lastly, did you confirm stable BIAS and mV over the emitters before testing, and that the pot is in good working condition? I don't think the pot is the real issue, but....
The headache is the burned powertransistors. This I haven't seen in "testmode" unless someone forgot to use white thermal paste and insulation between the heatsink and tanies....
Best regards
Best regards
