Thanks a lot for the nice wordsThat pot arrived very quickly.
Very nice job on the install, the owner should really appreciate your clean work.
I thought about doing the same thing to connect the pot. I ended up with the wire solution, to avoid stress on the solderings Vs extra pinouts that is solid connected to a pot that might handle some stress nevertheless when mounted on the chassisThanks for your help Mondialfan. ordered pot from Parts Express, came in two days. Built up some silver solder "posts" to make up for the diminutive leads of the new unit.
Q: The Acurus preamps lineup has no BIAS adjustment like most Aragon's, would slight lower value at R16/17 benefit the Acurus to increase BIAS?
What is the optimal BIAS in Aragon btw?![]()
The volumepot still makes a minor pop now and then after cleaning. Compared to the NOBEL-pots, having the original ALPS at the table the ALPS seams cheap(!) although many use them and find them good.
I decided not to spend more time on this one and looked online for the "Blue Velvet"-series witch were out of stock, so I ordered a 20K TKD CP2-601 as replacement.
View attachment 2998905TKD (Ko-on) 2CP-601 20K dual log taper potentiometer | HIFICollective
TKD (Ko-on) 2CP-601 20K dual log taper potentiometerwww.hificollective.co.uk
I'll post my feelings/findingsI've heard good things about TKD but never tried one myself, so I'll be interested in what you think of them.
The plastic films are supposed to be excellent.I've heard good things about TKD but never tried one myself, so I'll be interested in what you think of them.
Great answer. I measured around in the LS11 and found the mA-values quite small. Nevertheless your post answers why. I did try to find some heatsinks that'll fit the jfet's but didn't succeed. Initially I'll rest my case, they run at about maximum 34°C at normal listeninglevels witch is ok, but I'm not that fond of burning them in the chase of high BIASLowering the value of R16/R17 will not affect the bias in the Acurus to any significant degree. You'd need to cut the trace between the gates of Q7/Q8 and put a variable resistor there using a very low value of 100ohms or so. However I do not recommend this. The jfet's will conduct with the gate and source at the same potential so they're essentially a normally ON device. They have an IDSS value that they will idle at given the DC rail voltage at the Drain with no voltage at their gate. This is generally the given bias current with no adjustment to the gate voltage. I've not seen a preamp design with jfet's at the output that allowed adjustment of the bias current. The mosfet's that Mondial used in the Aragon pre's are an enhancement mode device so they're normally off and it requires a voltage at the gate to turn them on and raising this voltage will give more bias current.
There's a big problem with cutting the trace and adding a potentiometer on the Acurus pre's. In the LS11/RL11 the output k389/j109 jfet pairs are only rated for 400mW Pd (Power dissipation) or 200mW each individual jfet. If you calculate the power dissipated you'll find that the k389/j109's are already idling at around 40 - 60% of their rated Pd. For a long life is generally preferred to keep the Pd at 50% or less is generally preferred. Turning this bias current up will almost certainly result in shorter device life due to running hotter. The K147/J72 jfet's in the L10 fare a little better in that they're rated for 650mW for the output device, but I think its still a bad idea here as well.
The mosfet used in the Aragon pre's is a TO-220 device rated for 15W Pd, which is massive overkill for its purpose in that preamp. Thus you can run very high bias currents that are not possible in the Acurus preamps without fear of losing longevity in the output device. Even then I do not think that running more than 30mA in the Aragon's has any audible benefit, I have generally begun setting the bias around 25mA when I work on them. In comparison, the Acurus pre's are generally 10 -12mA of output stage bias, some of the earlier L10's may be as low as 7 - 8mA.
I'd recommend that if you really feel that you need the additional bias current in the output stage then you should sell the Acurus and buy an Aragon preamp.
What do you basically do to upgrade L10?Lowering the value of R16/R17 will not affect the bias in the Acurus to any significant degree. You'd need to cut the trace between the gates of Q7/Q8 and put a variable resistor there using a very low value of 100ohms or so. However I do not recommend this. The jfet's will conduct with the gate and source at the same potential so they're essentially a normally ON device. They have an IDSS value that they will idle at given the DC rail voltage at the Drain with no voltage at their gate. This is generally the given bias current with no adjustment to the gate voltage. I've not seen a preamp design with jfet's at the output that allowed adjustment of the bias current. The mosfet's that Mondial used in the Aragon pre's are an enhancement mode device so they're normally off and it requires a voltage at the gate to turn them on and raising this voltage will give more bias current.
