ADVENT 6003 speaker crossover
Ty67
I have a pair of Advent 6003 3-way speakers figured I would post a picture of the crossover for your viewing pleasure. The Capacitors are 40.0 UF, 12.0 UF, 8.0 UF and a 3.0 UF.
Thanks for the peek inside. Nice images -- good enough to trace out a schematic.
The only uncertainty is value of the resistor connected to the 40µF cap in the woofer circuit. Looks like 5Ω or maybe 6Ω?
[ EDIT -- updated schematic per post #4 below ]
Schematic can be updated if you can verify its value.
Interesting that the tweeter has a black wire from + input side and yellow wire from – input. Suggests that it's connected inverse phase to mid and woofer.
Those NPEs are nearly 40 years old. Are you recapping?
Yes I did a recap using MPT (Taiwan) all film capacitors. The Advent's 6003 sound much better than they did with the 35-year-old electrolytics.
What a difference! I was entertaining doubts that a film replacement set could be made to fit -- especially 40µF for the woofer. But the mission was obviously a success. Kudos!
Thanks for verifying that resistor value. Schematic updated.
You're welcome Stuart. It's only my third crossover and I still have a lot to learn. I hope there's some valuable info here for other 6003 owners out there.
Anyone out there know if the Advent Maestro (which I believe uses the same woofer, midrange, and tweeter as the 6003?) uses the exact same crossover network as the 6003?
Hey Ty67.. I have a pair of these Advents.. I'm considering recapping.. was a night and day improvement? Are the caps you used any good? they seem economical enough.. would you think it would be worth spending a few extra buck on something like clarity caps? Thanks!
