Or magnets...
Of course I don't know what stuff you were trying out, but actually this could be in line with Korf. The nice part of his formula is that the results are more forgiving than the standard ones. Basically most combinations work out OK when it comes to resonance frequencies. High mass arms with high compliance cart do get a mostly harmless hump (provided the arm does bearings and vibration damping correctly). The main problem is from low mass arms with lower compliance carts. Seems quite reasonable.
I'll only add that the B&K paper goes a little further in examining resonance-induced tracking issues, avoiding obvious mismatches seems to still make a lot of sense.
I'm acquainted with the paper - actually had it recommended by Alex Korf himself a couple of years ago. I'm honestly - not critically - curious, which part of it are you referring to?
It's a fantastic paper - recommended for anybody who hasn't already studied it. But I fail to see how the cited part would go beyond what I think is Korf's point.
What he is saying isn't that these resonances do not exist or don't matter, only that their actual level and frequencies do not follow from the "standard" calculations. Once you have a setup able to provoke them badly enough, you will get exactly what the B&K paper shows. Most effectively by combining a low compliance cart with a low mass arm. Or do I miss something in my reading of the paper?
Well B&K didn't seem to struggle with the formula, they in fact seemed to prove the math experimentally. The trouble (as some pointed-out above) is that the values we're provided by manufacturers these days are often wrong.
For many years res freq is recommended to be between 8 to 12Hz. Do Korf has another recommendation?
The B&K paper is an app note presented at a convention - not peer reviewed and not published as such. It's cursory data with a lot of hand-waving over the most interesting bits. I don't happen to have any records with .2mm radial slits in them that I listen to, so that data isn't all that useful to me, especially in consideration that most of it lacks vertical scales. Instead we get 'obviously this is audible'. I don't think it was ever intended to be an epitome on the concepts raised, rather just background to support the papers conclusion.
I just need to point out that the analysis in the B&K paper is fundamentally flawed. The conclusion was that a low mass arm with damping was better than two other medium mass arms without damping. Unless the conditions for testing are the same (ie all damped or all undamped) you cannot draw a conclusion about where the resonance frequency should lie.
A cynical take on the paper would be seeing it as an advertisement for what can be done with their kit on turntables. Still an interesting paper, and sadly one of the very few on the topic in the public domain.
My entire point here has been that the Korf stuff would deserve further research. There hasn't been much of progress in the field for some time now.
Well let's examine it another way, then, have there been any peer-reviewed papers contradicting B&K's work?
Still, the gist of the paper should still be valid, if taken for what it was meant to be.
