Altecs?
Frankie's Market
AK Member
Hi, can somone identify these Altecs? Seller says the dimensions are
24"h x 22-1/2”w x 17"d. No other information. Any idea on value? Thanks, Ed
Nothing - no markings of any kind on the rear panel?
If not, will probably need to pull the rear panel off to positively identify the driver(s?).
Very possibly a coaxial driver w/small horn...
I don't think a Valencia either which has an 811 horn so you'd see a rectangular cutout.
BTW - Valencia would be a very good thing...
if it's a factory build, and load, it will have a 420 in it, and likely have a tag somewhere identifying it as a model 870/870A.
if it was bought as an empty cabinet(model 461) it would have included the 15 inch to 12 inch adapter ring and could easily have been purchased along with 601A/B/C duplexes, or 412A/B/C, or the later 419 biflex. it was not uncommon in the 60's for drivers and cabinets to be sold separately.
I think you should go get 'em. There's a chance that those are 604 variety fullrangers.
Looks like a hole for a 15" or 12" woofer and a rectangular hole for a 3000-series tweeter.
Looks like Seville cabs without the lattice grills, but kinda wide for Seville cabs.
Yes, there's also a chance they're loaded with Tannoy Red or Black, or RCA LC-1A. Nearly anything is possible.
I'll wager they're loaded with 420 bi-flex, or 601C.
Not to be Capt. Obvious, but maybe you should email the seller and ask them what the plaque on the left speaker says.:D Centered on the bottom.
