They would work together, but there are many other factors to determine if they would sound good. The speaker specs are a little concerning. I see a lot of car speakers with 4ohm impedance, a lot of HTIB speakers with 3ohm impedance, but I rarely see an impedance of 2ohms which you have with the BOSS speakers. Were you planning to run both sets of speakers from the amp's L/R channels? What are you planning for a sub? Wiring both pairs of L/R speakers in series will result a 6ohms load where in parallel it would be 1.33ohms. These are resistance readings. Impedance readings are for AC resistance and change with frequency, so may go lower or higher than the nominal readings. In the car audio world this may not be unusual, but in home audio the 1.33ohm nominal impedance is not good.
